Product
Brand
Hive Active Light Dimmable - Bayonet (B22)
Quicklinx: D2CTWS00 Mfr#: HALIGHTDIMWWB22
Hurry, only 3 left in stock!
£15.84 ex VAT
£19.00 inc VAT
Express delivery Order within the next 3 hours for delivery tomorrow
Hive Active Light Dimmable - Bayonet fitting
Down for Sunday night, up for Monday morning: set our dimmable smart bulb to the level you want with a tap of the Hive app.
  • Just replace your existing light bulb with a Hive Active Light and pair with your Hive Hub.
  • Set schedules and pick your brightness to match the moment.
  • Save energy by controlling your lights remotely. A great way to reduce your energy bills.
Make time in the morning
Turn your lights off from your phone after you’ve left for work.
Keep the bogeyman at bay
Little ones afraid of the dark? Connect your Hive Active Light to a Hive Sensor with Hive actions, so as soon as they’re up, the landing light is too.
Movie nights done right
Lower the lights without leaving your sofa using your Hive app.
Hive Active Light - LED light bulb
Light Bulb Type
LED light bulb
Socket Type
B22
Wattage
9 W
Light Bulb Energy Efficiency Class
A+
Colour of Illumination
Warm white light
Colour Temperature
2700 K
Beam Angle
240 degree(s)
Dimmable
Light Bulb
LED light bulb
Socket Type
B22
Wattage
9 W
A+
Energy Consumption per 1000h
9 kWh
Warm white light
Colour Temperature
2700 K
Beam Angle
240 degree(s)
Dimmable
Lifetime
25000 hours
Android compatible, iOS compatible
Package
Box
Diameter
60 mm
Length
120 mm
80 g
71 mm x 71 mm x 136 mm / 129 g
