Hive Light Cool to Warm - Scewfit (E27)
Quicklinx: D2CXWS00 Mfr#: HALIGHTTUNEWE27
Hive Active Light - Cool to Warm White - Screw fitting
Match the lighting to your mood. Adjust our Cool to Warm White smart bulb from your smartphone.
- Just replace your existing light bulb with a Hive Active Light and pair with your Hive Hub.
- Set schedules and pick your brightness and warmth to match the moment.
- Save energy by controlling your lights remotely. A great way to reduce your energy bills.
Stay focused for longer
Stay energised when you're working late by tuning your Hive Active Light to a cooler shade of white.
Jetting off into the sun?
Schedule your Hive Active Light to come on every evening to give you the peace of mind that it looks like somebody's home.
Come home to a brighter welcome
Flick your lights on from outside when you reach the front door.
Hive Active Light - LED light bulb - E27 - 9 W - cool daylight/warm white light - 2700-6500 K
Light Source Type
LED light bulb
Socket Type
E27
Wattage
9 W
Colour of Illumination
Cool daylight/warm white light
Colour Temperature
2700-6500 K
Beam Angle
240 degree(s)
Dimmable
Platform
Hive
Light Source
LED light bulb
Socket Type
E27
Wattage
9 W
Colour Temperature
2700-6500 K
Beam Angle
240 degree(s)
Dimmable
Lifetime
25000 hours
Android compatible, iOS compatible, light scheduling, shadow-free
Internet of Things (IoT)
Hub Compatibility
Hive Hub
Platform
Hive
60 mm
120 mm
119 g
71 mm x 71 mm x 136 mm
