Hive Active Light - Colour Changing - Bayonet fitting
Match your lighting to your moods with our colour-changing smart bulb, in 16 million colours.
- Just replace your existing light bulb with a Hive Active Light and pair with your Hive Hub.
- Set schedules and pick your brightness and colour to match the moment.
- Save energy by controlling your lights remotely. A great way to reduce your energy bills.
Get the party started
Jazz up the colour of your home using our colour-changing smart bulb.
Make time in the morning
Turn your lights off from your phone after you've left for work.
Come home to a brighter welcome
Flick your lights on from outside when you reach the front door.
Save energy, save money
These long-lasting smart bulbs are energy efficient, and by controlling them remotely you can make sure they're not left on. -
Get the lighting just right from wherever you are
Manage your lighting on your phone, so it's just how you like it, just when you need it. -
Set smart schedules
Personalize the lighting for every room and set schedules so your lights turn on and off automatically.
- Hive Active Light - LED light bulb - B22 - 9.5 W - RGB/white light - 2700-6500 K
- Light Source Type
- LED light bulb
- Socket Type
- B22
- Wattage
- 9.5 W
- Energy Efficiency Class
- A+
- Colour of Illumination
- RGB/white light
- Colour Temperature
- 2700-6500 K
- Luminous Power
- 806 lumens
- Beam Angle
- 240 degree(s)
- Dimmable
- Platform
- Hive
- Communications Technology
- Bluetooth
- Voltage Required
- AC 220 - 240 V
Light Source
- LED light bulb
- Socket Type
- B22
- Wattage
- 9.5 W
- A+
- RGB/white light
- 2700-6500 K
- Luminous Power
- 806 lumens
- Beam Angle
- 240 degree(s)
- Dimmable
- Lifetime
- 25000 hours
- Android compatible, iOS compatible, indoor usage
Power Requirements
- Voltage Required
- AC 220 - 240 V
Internet of Things (IoT)
- Platform
- Hive
- Bluetooth
- Package
- Box
- Diameter
- 60 mm
- Length
- 120 mm
- 122 g
- Shipping Dimensions (WxDxH) / Weight
- 71 mm x 71 mm x 136 mm / 169 g
