Product
Brand
Hive Active Light Colour Changing – Bayonet (B22)
Quicklinx: D2CYWS00 Mfr#: HALIGHTRGBWB22
10 in stock
£33.33 ex VAT
£39.99 inc VAT
Express delivery Order within the next 17 hours for delivery tomorrow
Hive Active Light - Colour Changing - Bayonet fitting
Match your lighting to your moods with our colour-changing smart bulb, in 16 million colours.
- Just replace your existing light bulb with a Hive Active Light and pair with your Hive Hub.
- Set schedules and pick your brightness and colour to match the moment.
- Save energy by controlling your lights remotely. A great way to reduce your energy bills.
Get the party started
Jazz up the colour of your home using our colour-changing smart bulb.
Make time in the morning
Turn your lights off from your phone after you've left for work.
Come home to a brighter welcome
Flick your lights on from outside when you reach the front door.
Hive Active Light - LED light bulb
Light Bulb Type
LED light bulb
Socket Type
B22
Wattage
9.5 W
Light Bulb Energy Efficiency Class
A+
Colour of Illumination
RGB/white light
Colour Temperature
2700-6500 K
Luminous Power
806 lumens
Beam Angle
240 degree(s)
Dimmable
AC 220 - 240 V
Light Bulb
LED light bulb
Socket Type
B22
Wattage
9.5 W
A+
RGB/white light
Colour Temperature
2700-6500 K
Luminous Power
806 lumens
Beam Angle
240 degree(s)
Dimmable
Lifetime
25000 hours
Android compatible, iOS compatible, indoor usage
Power Requirements
AC 220 - 240 V
Internet of Things (IoT)
Platform
Hive
Communications Technology
Bluetooth
Package
Box
Diameter
60 mm
Length
120 mm
122 g
71 mm x 71 mm x 136 mm / 169 g
