Hive Light Dimmable - Screw fitting
Down for Sunday night, up for Monday morning: set our dimmable smart bulb to the level you want with a tap of the Hive app.
- Just replace your existing light bulb with a Hive Light and pair with your Hive Hub.
- Set schedules and pick your brightness to match the moment.
- Save energy by controlling your lights remotely. A great way to reduce your energy bills.
Make time in the morning
Turn your lights off from your phone after you’ve left for work.
Keep the bogeyman at bay
Little ones afraid of the dark? Connect your Hive Light to a Hive Sensor with Hive actions, so as soon as they’re up, the landing light is too.
Movie nights done right
Lower the lights without leaving your sofa using your Hive app.
Save energy, save money
These long-lasting smart bulbs are energy efficient, and by controlling them remotely you can make sure they're not left on. -
Get the lighting just right from wherever you are
Manage your lighting on your phone, so it's just how you like it, just when you need it. -
Lighting how you like it
Personalize the lighting for every room and set schedules so your lights turn on and off automatically. -
Turn them off together
Group your Hive Lights so that you can control all of them together.
- Hive Active Light - LED light bulb - E27 - 9 W - warm white light - 2700 K
- Light Source Type
- LED light bulb
- Socket Type
- E27
- Wattage
- 9 W
- Energy Efficiency Class
- A+
- Colour of Illumination
- Warm white light
- Colour Temperature
- 2700 K
- Luminous Power
- 806 lumens
- Beam Angle
- 240 degree(s)
- Dimmable
- Voltage Required
- AC 220 - 240 V
Light Source
- LED light bulb
- Socket Type
- E27
- Wattage
- 9 W
- A+
- Energy Consumption per 1000h
- 9 kWh
- Warm white light
- 2700 K
- Luminous Power
- 806 lumens
- Beam Angle
- 240 degree(s)
- Dimmable
- Lifetime
- 25000 hours
- Android compatible, iOS compatible
Power Requirements
- Voltage Required
- AC 220 - 240 V
- Package
- Box
- Diameter
- 60 mm
- Length
- 120 mm
- 80 g
