Hive Active Light - Cool to Warm White - Bayonet fitting
Match the lighting to your mood. Adjust our Cool to Warm White smart bulb from your smartphone.
- Just replace your existing light bulb with a Hive Active Light and pair with your Hive Hub.
- Set schedules and pick your brightness and warmth to match the moment.
- Save energy by controlling your lights remotely. A great way to reduce your energy bills.
Stay focused for longer
Stay energised when you're working late by tuning your Hive Active Light to a cooler shade of white.
Jetting off into the sun?
Schedule your Hive Active Light to come on every evening to give you the peace of mind that it looks like somebody's home.
Come home to a brighter welcome
Flick your lights on from outside when you reach the front door.
- Hive Active Light - LED light bulb - B22 - 9 W - warm white light - 2700 K
- Light Source Type
- LED light bulb
- Socket Type
- B22
- Wattage
- 9 W
- Energy Efficiency Class
- A+
- Colour of Illumination
- Warm white light
- Colour Temperature
- 2700 K
- Luminous Power
- 806 lumens
- Beam Angle
- 240 degree(s)
- Dimmable
- Voltage Required
- AC 220 - 240 V
Light Source
- LED light bulb
- Socket Type
- B22
- Wattage
- 9 W
- A+
- Energy Consumption per 1000h
- 9 kWh
- Warm white light
- 2700 K
- Luminous Power
- 806 lumens
- Beam Angle
- 240 degree(s)
- Dimmable
- Lifetime
- 25000 hours
- Android compatible, iOS compatible
Power Requirements
- Voltage Required
- AC 220 - 240 V
- Package
- Box
- Diameter
- 60 mm
- Length
- 120 mm
- 80 g
