Hive Light Colour Changing – Bayonet (B22)
Quicklinx: D2CYWS00 Mfr#: HALIGHTRGBWB22
£33.33 ex VAT
£39.99 inc VAT
Hive Active Light - Colour Changing - Bayonet fitting
Match your lighting to your moods with our colour-changing smart bulb, in 16 million colours.
- Just replace your existing light bulb with a Hive Active Light and pair with your Hive Hub.
- Set schedules and pick your brightness and colour to match the moment.
- Save energy by controlling your lights remotely. A great way to reduce your energy bills.
Get the party started
Jazz up the colour of your home using our colour-changing smart bulb.
Make time in the morning
Turn your lights off from your phone after you've left for work.
Come home to a brighter welcome
Flick your lights on from outside when you reach the front door.
  • Save energy, save money
    These long-lasting smart bulbs are energy efficient, and by controlling them remotely you can make sure they're not left on.
  • Get the lighting just right from wherever you are
    Manage your lighting on your phone, so it's just how you like it, just when you need it.
  • Set smart schedules
    Personalize the lighting for every room and set schedules so your lights turn on and off automatically.
Hive Active Light - LED light bulb - B22 - 9.5 W - RGB/white light - 2700-6500 K
Light Source Type
LED light bulb
Socket Type
B22
Wattage
9.5 W
Energy Efficiency Class
A+
Colour of Illumination
RGB/white light
Colour Temperature
2700-6500 K
Luminous Power
806 lumens
Beam Angle
240 degree(s)
Dimmable
Platform
Hive
Communications Technology
Bluetooth
AC 220 - 240 V
Light Source
LED light bulb
Socket Type
B22
Wattage
9.5 W
A+
RGB/white light
Colour Temperature
2700-6500 K
Luminous Power
806 lumens
Beam Angle
240 degree(s)
Dimmable
Lifetime
25000 hours
Android compatible, iOS compatible, indoor usage
Power Requirements
AC 220 - 240 V
Internet of Things (IoT)
Platform
Hive
Bluetooth
Package
Box
Diameter
60 mm
Length
120 mm
122 g
71 mm x 71 mm x 136 mm / 169 g
