Hive Multizone
Stay comfy and save money by creating different temperature zones in your house.
- Save energy by only heating parts of your home you’re using
- Set different rooms to different temperatures
- Control all your Hive thermostats from one place
Sahara, Seville, South Pole
Set up to three different temperature zones, so everywhere is just how you like it.
Set up and start saving
Only heat the parts of your home that you’re using at any time.
Multiple thermostats. One app.
Operate all your temperature zones from one place.
- Hive Active Heating - thermostat
- Product Type
- Thermostat
- Functions
- Control heating systems, location tracking, water control
- Power Source
- Battery
- Connectivity
- Wireless
- 10 cm x 4.8 cm x 10 cm
- Product Type
- Thermostat
- Functions
- Power Source
- Battery
- Connectivity Technology
- Wireless
- Power scheduling, frost protection, holiday mode
- Form Factor
- AA type
- Battery Included
- Required Qty
- 4
- Technology
- Alkaline
- 10 cm
- 4.8 cm
- 10 cm
- 212 g
