Easy installation - selection of wide zoom bayonet lenses, wide vertical and horizontal lens shift and control code emulation guarantees hassle-free installation and replacement of old installation projectors. Easy way to a big picture - up to 4K interface, HDMI-out signal loop through, built-in signal splitter and edge blending capability enables large presentation pictures without any external devices. PiP function allows additional sources to be displayed.
Free Download of Multi-Display Management Software - with NaViSet Administrator 2 you can manage all your connected display devices from a centralized location. Very low cost of ownership - long lamp life of up to 4000 hours, inorganic long life panels, maintenance free filters and standby power of just 0.15W. Widest application support - portrait mode projection, 360 degree free tilt installation, unique geometric adjustment and 3D support offers unrivaled installation capability.
Rich connectivity - including HDBaseT, the world's first HDMI-out interface, 2xHDMI and DisplayPort technology guarantees outstanding connectivity. Perfect Image quality - high brightness, up to 4K input signal and unique picture and color processing technology based on the latest NEC scaler chip achieves outstanding picture quality.
- NEC PA522U - LCD projector - no lens - 3D - LAN
- LCD projector - 1080p
- 3D Capable
- Brightness
- 5200 ANSI lumens
- Contrast Ratio
- 5000:1
- Resolution
- WUXGA (1920 x 1200)
- Native Aspect Ratio
- 16:10
- Lens
- No lens
- Lens Shift Direction
- Horizontal, vertical
- Bulb type
- UHP 330 Watt
- Bulb life cycle
- Up to 3000 hour(s) - normal mode , Up to 4000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video, component video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60), LAN
- Video Modes
- 1080/24p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 1080/30p, 1080/25p, 576/50i, 480/50i
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50 - 60 Hz)
- 460 Watt
- 49.9 cm x 35.9 cm x 14.2 cm
- 8.4 kg
- 3-year warranty
- 3D Capable
Projector
- Brightness
- 5200 ANSI lumens
- Contrast Ratio
- 5000:1
- Image Size
- 76 cm - 1270 cm
- Resolution
- WUXGA - WUXGA (1920 x 1200)
- 16:10
- Max Sync Rate (V x H)
- 120 Hz x 153 kHz
- Bulb type
- UHP 330 Watt
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- Picture in picture, 3D Reform technology, Micro Lens Array (MLA) Technology, Edge blending, wall colour correction, Side-by-Side, PJlink, Crestron RoomView, Intelligent Power Management, DICOM Simulation Mode, Direct Power Off, Geometric Correction, Cinema Quality Picture (CQP) Processing, Multi-Screen compensation mode
Lens
- No lens
- Focus Type
- Manual
- Zoom Type
- Manual
- Keystone Correction Direction
- Vertical Keystone Correction
- -40 / +40
- Horizontal Keystone Correction
- -40 / +40
Video Input
- TV System
- NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, DisplayPort, composite video, S-Video, RGB
- Video Modes
- LAN and Wireless Image Transferring Protocols
- Wired LAN
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 10 Watt
- Speakers
- 1 x mixed channel
- 5 x composite / component video / S-Video / RGB input - BNC , 1 x VGA input - 15 pin D-Sub (DB-15) , 1 x DisplayPort input - 20 pin DisplayPort , 1 x HDBaseT - RJ-45 , 2 x HDMI input - 19 pin HDMI Type A , 1 x HDMI output - 19 pin HDMI Type A , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 1 x USB 2.0 - 4 pin USB Type A , 1 x 3D Sync out - 3 PIN mini-DIN , 1 x remote control - mini-phone stereo 3.5 mm
- Included Accessories
- Wireless remote control
- Security Features
- Security lock slot (cable lock sold separately), password protection
- TUV GS, RoHS, ERP
- Voltage Required
- 460 Watt
- Power Consumption Stand by
- 0.16 Watt
- 49.9 cm
- 35.9 cm
- 14.2 cm
- 8.4 kg
- Limited warranty - 3 years , Limited warranty - lamp - 6 months / 1000 hours
- Sound Emission
- 39 dB
- Sound Emission (Economic Mode)
- 33 dB
