The CP-X8150 projector is geared up for simple and user-friendly functionality in any environment. With a convenient motorized lens shift, and a central lens position, images can be seamlessly adjusted and moved at the touch of a button. Plus, with a wide range of optional lenses, the CP-X8150 can adapt to any environment, from conference rooms and lecture theaters, to museums or anywhere requiring a creative solution.
3LCD
A sophisticated, innovative technology that utilizes 3 chips to deliver vibrant, true-to-life and consistent images for the most demanding audiences. -
Hybrid Filter
The Hybrid Filter lasts longer than conventional filters. This extension in maintenance intervals reduces the overall cost of ownership significantly. -
Security features
Advanced security features include Multi-Level PIN-Lock, Transition Detector, steel security bar, Kensington Lock and prominent security labels. -
Blackboard/Whiteboard Mode
Projecting onto colored or shiny backgrounds can make images appear either dull or uncomfortably bright. This mode ensures optimal brightness whether the screen is black, green or shiny white. -
Low TCO
Significantly extended maintenance intervals resulting from long-life parts reduces the total cost of ownership. -
Optional Lenses
Installations are more flexible with a range of optional bayonet lenses. Choose from Fixed Short, Short, Long and Ultra Long throw lenses, designed to suit different requirements. -
PC-less Presentations
Simply plug in a memory stick, SD card, or even a portable hard disk drive and present without the need of a laptop. -
Vertical Projection
Images can be projected at 90 degrees up or down, opening up a whole new range of applications. -
Advanced Networking
Manage and control multiple projectors over LAN. Turn the projector on and off, schedule email alerts and monitor projectors all via the network. -
Wireless Networking
Wireless networking offers quick, easy and secure network access. Browser based software provides easy management, control and monitoring of networked projectors. -
AMX Device Discovery
When integrated with an AMX Controller, the relevant communication modules and drivers are downloaded to the projector automatically. -
HDMI
Get the highest quality image by connecting the latest in A/V equipment to the projector with HDMI (High-Definition Multimedia Interface). -
Long Life Lamp
Using Eco Mode, lamp life is extended to more than 6,000 hours - equivalent to the projector being used for three hours a day over a period of ten years. -
Template Function
This unique Hitachi feature allows you to project different patterns of lines and grids onto a whiteboard, blackboard or flip chart, making writing and drawing easier. -
Virtually Maintenance Free
Hitachi projectors are designed to be easy to use and require minimal maintenance. Long-life parts significantly extend the maintenance intervals, reducing cost and any inconvenience. -
Daytime Mode
It can be harder to see a projected picture when the sun is shining brightly. Projections are always vivid and colorful in a bright environment with Daytime Mode. -
Quick On/Off
Plug in, turn on and present. The Quick On/Off feature and automatic resolution equals fast set-up. -
Input Source Naming
Personalize devices and inputs to the projector - for example, re-name a device input to "Tom's Laptop" for easy recognition. -
Ultra Quiet
The internal fan is one of the quietest in its class. The audience will hear the presenter, not the operating noise of the projector. -
My Button
Assign custom functions or common tasks to a programmable button on your remote control. -
Messenger
Send text messages and announcements to multiple, networked projectors at the same time. This is ideal for projecting daily work schedules and university campus notifications to multiple classrooms simultaneously. -
Centralized Reporting Function
Using a single PC, create HTML reports for a group of networked projectors to simplify maintenance requirements. -
Audio Pass Through
When all you need is sound and not pictures, this convenient feature lets you hear the projector's speakers whilst the rest is on stand-by - helping to preserve lamp life. -
Vertical Keystone Correction
Correct misaligned images automatically with vertical keystone correction. -
Progressive Scan
Typically with moving images, each frame of video is shown in two halves - odd lines and even lines. Progressive Scan enables every line of a video frame to be displayed simultaneously resulting in crisp, smooth motion and reduced flicker and judder. -
On Screen Display (OSD)
The new menu is much easier to use. Navigating through the different options is easier, whilst settings are clearly named.
- Hitachi CP-X8150
- Resolution
- XGA (1024 x 768)
- Video Input
- RGB, composite video (SECAM)
- Video Modes
- 720/50p
- Power
- AC 120/230 V
Projector
- Resolution
- XGA (1024 x 768)
Video Input
- TV System
- SECAM
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video
- Video Modes
- 720/50p
- Nominal Voltage
- AC 120/230 V
