Hitachi 3200 Lumens XGA Resolution LCD Technology Meeting Room Projector
Quicklinx: BJFCWS00 Mfr#: CPEX301N
Hitachi education projectors bring together innovative features for superior picture quality. Motion Adaptive Progressive Scan reduces line flicker, boosting resolution and smoothing moving images. Noise Reduction boosts clarity. And Hitachi's unique Equalizing Gamma Function helps you customise gamma and color balance to suit your preferences.
  • Saver Mode
    The Saver Mode reduces lamp power by 70% compared to Normal Mode, resulting in considerable energy savings. You can set the time for Saver Mode from 1 to 30 minutes. If the projected image does not change within the set time, the Saver Mode is activated.
  • Intelligent Eco Mode
    When Intelligent Eco Mode is selected, the lamp power adjusts according to screen brightness. Lamp power decreases when the image is dark and increases when the image is bright. Using Intelligent Eco Mode increases the contrast ratio of the projector while decreasing the use of electricity.
  • High picture quality
  • Blackboard and whiteboard modes
    Projecting onto colored backgrounds can make images appear dull - shiny backgrounds can make them uncomfortably bright. With these blackboard and whiteboard modes, you can ensure optimal brightness whether the screen is black, green or shiny white.
Hitachi CP-EX301N - 3LCD projector
3LCD projector
Built-in Devices
Speaker
Brightness (White)
3000 lumens
Brightness (Colour)
2460 lumens
Contrast Ratio
2000:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Colour Support
16.7 million colours
Bulb type
225 Watt
Bulb life cycle
Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
Video Input
RGB, composite video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43)
Video Modes
480p, 480i, 525i, 525p, 625i, 576i, 1080/60i, 720/60p, 1080/50i, 720/50p, 750p, 1080/50p, 1080/60p, 1125i, 1125p
Speakers
Speaker(s) - integrated
32 cm x 24.5 cm x 8.5 cm
3 kg
3-year warranty
3LCD projector
Built-in Devices
Speaker
Ethernet
Projector
Brightness (White)
3000 lumens
Brightness (Colour)
2460 lumens
Brightness (Reduced)
2460 lumens
Contrast Ratio
2000:1
Image Size
76 cm - 762 cm
Projection Distance
0.91 m - 10.9 m
Throw Ratio
1.5 - 1.8:1
Resolution
XGA - XGA (1024 x 768)
Native Aspect Ratio
4:3
Colour Support
Bulb type
225 Watt
Bulb life cycle
Controls & Adjustments
Gamma correction, colour temperature, keystone correction
OSD Languages
Danish, Hungarian, Czech, Croatian, Slovenian, Indonesian, Thai, Chinese (traditional), Chinese (simplified), Vietnamese, Brazilian Portuguese, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Latvian, Lithuanian, Estonian, Romanian, Japanese, Korean, Persian
Eco-Mode technology, freeze frame, Blackboard Mode, integrated de-interlacer (progressive scan), Closed Caption, High-bandwidth Digital Content Protection System (HDCP), Noise Reduction, Greenboard Mode, 3LCD Technology, 3:2 pull down compensation, Whiteboard Mode, input source naming, PJlink, Crestron RoomView, Template Function, Direct Power On, blank screen, ImageCare Technology, MyScreen, Auto Power Off
Lens
Focus Type
Manual
Zoom Type
Manual
Zoom Factor
1.2x
Keystone Correction Type
Digital
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-30 / +30
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
16 Watt
Speakers
1 x mixed channel
1 x HDMI - 19 pin HDMI Type A , 2 x VGA input - 15 pin D-Sub (DB-15) , 1 x VGA input / output - 15 pin D-Sub (DB-15) , 1 x composite video input - RCA , 1 x audio line-in - RCA x 2 , 1 x audio line-out - RCA x 2 , 1 x serial RS-232C - 9 pin D-Sub (DB-9) (management) , 1 x network - RJ-45 (management) , 1 x USB - 4 pin USB Type B
Remote control
1 x VGA cable
Security Features
Security lock slot (cable lock sold separately), password protection, PIN code, security bar, My Screen lock, keypad lock
Plug and Play, cUL, DDC-2B, EN 61000-3-2, EN55022, EN 61000-3-3, EN55024, C-Tick Class B, FCC Part 15 B, RoHS, UL 60950-1, EN 60950-1, WEEE, ErP Ready
Power Source
AC
Power Consumption Stand by
0.5 Watt
32 cm
24.5 cm
8.5 cm
3 kg
Limited warranty - 3 years , Limited warranty - lamp - 6 months
Sound Emission
37 dB
32 dB
