Hitachi 3000 Lumens XGA DLP Technology Meeting Room Projector
Quicklinx: BBZYWS00 Mfr#: CPDX300
Hitachi's CP-DX300 DLP projector represents the standard for classroom environments and versatility with high resolution XGA performance, an innovative feature set and overall value. The CP-DX300 incorporates 3,000 ANSI lumens light output and a 2500:1 contrast ratio for vibrant, bold images with deeper black levels and razor-sharp text. Performance versatility is enhanced by HDMI terminals which accommodate many types of AV devices. Plus, Hitachi's intelligent eco mode with ImageCare combines optimal picture performance with energy savings for a lower cost of ownership.
  • 3,000 ANSI lumens light output
    The light output specification measures the brightness of light output and with 3,000 ANSI lumens the result is bright, clear, true to life images with incredible detail.
  • 2500:1 contrast ratio
    Contrast can be automatically controlled through an active iris to add depth perspective during both bright and dark scenes.
  • HDMI input (HDCP)
    Digital connectivity allows for highest image quality from your HD device. Compliancy with HDCP.
  • Power saving standby mode
    Power saving mode reduces the standby power consumption to less than 0.5 W.
  • BrilliantColor
    BrilliantColor technology is setting a standard in color performance. BrilliantColor offers color processing to enhance color performance for rich, vibrant and accurate colors.
  • DLP technology
    DLP technology was invented, developed and is owned by Texas Instruments. The DLP chip is a digital semiconductor that contains millions of microscopic mirrors. These projectors use DLP technology to project images with amazing quality.
  • Easy maintenance
    Easy maintenance is another attractive function, as the lamp door is on top of the model.
  • Wall color correction
    This feature corrects the color of images projected on surfaces that are not white to prevent color differences between the source and projections. Five wall color modes include light yellow, light green, blue, black board and pink.
  • 3D capable
    Discover the teaching advantages of 3D! This DLP projector offers the latest trend for the classroom with 3D viewing. It will engage your students and can improve the learning process.
Hitachi CP-DX300 - DLP projector - portable - 3D
DLP projector
3D Capable
Built-in Devices
Speaker
Brightness
3000 ANSI lumens
Contrast Ratio
2500:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Colour Support
1.07 billion colours
Bulb type
UHP 196 Watt
Bulb life cycle
Up to 4500 hour(s) - normal mode , Up to 6000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video, component video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43)
Video Modes
480p, 480i, 525i, 525p, 625i, 576i, 1080/60i, 720/60p, 1080/50i, 720/50p, 750p, 1080/50p, 1080/60p, 1125i, 1125p
Speakers
Speaker(s) - integrated
250 Watt
26.5 cm x 22.3 cm x 8.15 cm
2.2 kg
3-year warranty
DLP projector
3D Capable
Built-in Devices
Speaker
Projector
Brightness
3000 ANSI lumens
Brightness (Reduced)
2600 ANSI lumens
Contrast Ratio
2500:1
Image Size
76 cm - 762 cm
Projection Distance
1 m - 12 m
Throw Ratio
1.86 - 2.04:1
Resolution
XGA - XGA (1024 x 768)
Native Aspect Ratio
4:3
Colour Support
Max Sync Rate (V x H)
120 Hz x 102 kHz
Bulb type
UHP 196 Watt
Bulb life cycle
Controls & Adjustments
Keystone correction
OSD Languages
Hindi, Hungarian, Czech, Indonesian, Thai, Chinese (traditional), Vietnamese, Brazilian Portuguese, English, German, French, Italian, Polish, Swedish, Russian, Spanish, Greek, Turkish, Arabic, Japanese, Korean
sRGB colour profile, freeze frame, Blackboard Mode, Auto Input Search, Closed Caption, High-bandwidth Digital Content Protection System (HDCP), wall colour correction, BrilliantColor, DLP 3D Ready, 16:9 aspect ratio support, Game mode, upgradable firmware, ImageCare Technology, Auto Power Off, Mirror Reverse image, Auto Eco Mode
Lens
Focus Type
Manual
Zoom Type
Manual
Zoom Factor
1.1x
Keystone Correction Type
Digital
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-30 / +30
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
2 Watt
Speakers
1 x mixed channel
1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x HDMI input - 19 pin HDMI Type A , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 1 x USB - 4 pin USB Type B (management)
Wireless remote control
1 x VGA cable
Security Features
Security lock slot (cable lock sold separately), password protection, security bar
TUV GS, cUL, DDC-2B, EN 61000-3-2, EN55022, EN 61000-3-3, EN55024, FCC Part 15 B, RoHS, UL 60950-1, EN 60950-1, WEEE, GOST-R, Energy-Related Products (ErP) Lot 6
Power Source
AC
250 Watt
Power Consumption Stand by
0.5 Watt
26.5 cm
22.3 cm
8.15 cm
2.2 kg
Limited warranty - 3 years , Limited warranty - lamp - 6 months
35 °C
Sound Emission
35 dB
31 dB
