Discover the teaching advantages of 3D! This DLP projector offers the trend for the classroom with 3D viewing. It will engage your students and can improve the learning process. 3D glasses and a special graphic card are required for 3D viewing and are not included with the projector.
3D capable
Discover the teaching advantages of 3D! This DLP projector offers the trend for the classroom with 3D viewing. It will engage your students and can improve the learning process. 3D glasses and a special graphic card are required for 3D viewing and are not included with the projector. -
DLP technology
DLP technology was invented, developed and is owned by Texas Instruments. The DLP chip is a digital semiconductor that contains millions of microscopic mirrors. These projectors use DLP technology to project images with amazing quality. -
BrilliantColor
BrilliantColor technology is setting a standard in color performance. BrilliantColor offers color processing to enhance color performance for rich, vibrant and accurate colors. -
Wall color correction
This feature corrects the color of images projected on surfaces that are not white to prevent color differences between the source and projections. -
ImageCare
ImageCare is the technology that regulates lamp power, combing optimal picture performance with maximum energy savings. -
HDMI
Get the highest quality image by connecting the latest in A/V equipment to the projector with HDMI (High-Definition Multimedia Interface).
- Hitachi CP-DH300 - DLP projector - portable
- DLP projector - 1080p
- Built-in Devices
- Speaker
- Brightness
- 3000 lumens
- Contrast Ratio
- 2000:1
- Resolution
- Full HD (1920 x 1080)
- Native Aspect Ratio
- 16:9
- Colour Support
- 1.07 billion colours
- Bulb type
- UHP 210 Watt
- Bulb life cycle
- Up to 4000 hour(s) - normal mode , Up to 5000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60)
- Video Modes
- 480p, 480i, 576i, 576p, 1080/60i, 720/60p, 1080/50i, 720/50p, 1080/50p, 1080/60p
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V
- 260 Watt
- 26.5 cm x 22.3 cm x 8.15 cm
- 2.2 kg
- 3-year warranty
- Built-in Devices
- Speaker
Projector
- Brightness
- 3000 lumens
- Contrast Ratio
- 2000:1
- Image Size
- 76 cm - 762 cm
- Resolution
- 16:9
- Colour Support
- Bulb type
- UHP 210 Watt
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- OSD Languages
- Hindi, Hungarian, Czech, Indonesian, Thai, Chinese (traditional), Vietnamese, Brazilian Portuguese, English, German, French, Italian, Polish, Swedish, Russian, Spanish, Greek, Turkish, Arabic, Japanese, Korean
- Closed Caption, wall colour correction, ImageCare Technology, Auto Power Off
Lens
- Keystone Correction Type
- Digital
Video Input
- TV System
- NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video
- Video Modes
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 2 Watt
- Speakers
- 1 x mixed channel
- 2 x RGB input - 15 pin HD D-Sub (HD-15) , 1 x RGB output - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x HDMI - 19 pin HDMI Type A , 1 x S-video input , 1 x serial RS-232C - 9 pin D-Sub (DB-9) , 1 x USB - 4 pin USB Type B
- Security Features
- Security lock slot (cable lock sold separately), keypad lock
- UL, cUL, GS, CB, FCC, GOST-R, RCM
- Voltage Required
- AC 120/230 V
- 260 Watt
- Power Consumption Stand by
- 0.5 Watt
- 26.5 cm
- 22.3 cm
- 8.15 cm
- 2.2 kg
- Limited warranty - 3 years , Limited warranty - lamp - 6 months
- Sound Emission
- 34 dB
- Sound Emission (Economic Mode)
- 30 dB
