Your basket is empty
HGST Hitachi ULTRASTAR A7K2000 1TB 7200RPM SATA 32MB 3.5"
Quicklinx: 7CDHWS00 Mfr#: 0A39289
The Ultrastar A7K2000 provides twice the data storage capacity of the prior generation Ultrastar A7K1000 drive, and does so using fewer watts. Operating at 7200 RPM, the Hitachi Ultrastar A7K2000 offers better overall performance than slower-RPM, capacity-oriented drives at impressively low power-consumption rates. When compared to the previous generation Ultrastar A7K1000, the A7K2000 offers up to a 155% improvement in sustained data transfer rate, and a 120% improvement in watts-per-GB. With five Advanced Power Management modes, a 36% reduction in watts during low-RPM idle mode, and using less than 1W during standby/sleep mode, the Ultrastar A7K2000 can help data centers achieve lower AC power and HVAC requirements, freeing up precious headroom for growing enterprise needs.
With a robust fourth-generation mechanical design, Ultrastar A7K2000 is specifically built and tested for the enterprise. The Ultrastar SATA drive family features Hitachi-patented Rotational Vibration Safeguard (RVS) sensor technology, which optimizes drive reliability in multi-drive RAID arrays and rack-mounted systems.
The Ultrastar A7K2000 demonstrates Hitachi ecological leadership with its halogen-free design and power-efficient operation. Both these features serve to qualify the drive for the Hitachi EcoTrac classification, which identifies products that minimize environmental impact in the areas of product design, manufacturing, operation and disposal.
HGST Ultrastar A7K2000 HUA722010CLA330 - hard drive - 1 TB - SATA 3Gb/s
Hard drive - internal
1 TB
3.5" x 1/3H
SATA 3Gb/s
Data Transfer Rate
300 MBps
Buffer Size
32 MB
Spindle Speed
7200 rpm
10.2 cm x 14.7 cm x 2.6 cm
0.68 kg
Microsoft Certification
Compatible with Windows 7
5 years warranty
1 TB
3.5" x 1/3H
SATA 3Gb/s
Buffer Size
32 MB
10.2 cm
14.7 cm
2.6 cm
0.68 kg
Performance
Drive Transfer Rate
300 MBps (external)
Internal Data Rate
134 MBps
Seek Time
8.5 ms (average)
Spindle Speed
7200 rpm
Reliability
MTBF
1,200,000 hours
Non-Recoverable Errors
1 per 10^15
Start / Stop Cycles
300,000
Expansion & Connectivity
1 x SATA 3 Gb/s - 7 pin Serial ATA
Compatible Bay
3.5" x 1/3H
Limited warranty - 5 years
5 °C
60 °C
Shock Tolerance
70 g @ 1ms half-sine pulse (operating) / 350 g @ 1ms half-sine pulse (non-operating)
Vibration Tolerance
0.67 g @ 5-500 Hz (operating)
