Product
HGST Deskstar NAS H3IKNASN600012872SE Hard Drive 6TB SATA 6Gb/s 3.5" 7200rpm
Quicklinx: C7VBWS00 Mfr#: 0S03941
The Deskstar NAS hard drive is a 7200 RPM 3.5-inch hard drive that provides an exceptional blend of reliability and performance, making it an ideal solution for consumer and commercial desktop NAS systems. This NAS-ready hard drive from HGST delivers media transfer rates that are as much as 20% faster than 5400 RPM drives and seek times less than 12 ms. Furthermore, Deskstar NAS hard drives incorporate a rotational vibration sensor and achieve reliability of 1M hours MTBF.
HGST Deskstar NAS H3IKNASN600012872SE - hard drive - 6 TB - SATA 6Gb/s
Hard drive - internal
6 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
128 MB
Spindle Speed
7200 rpm
NAS compatible, rotation vibration sensor
101 mm x 146 mm x 26.1 mm
840 g
3 years warranty
6 TB
3.5"
SATA 6Gb/s
Buffer Size
128 MB
101 mm
146 mm
26.1 mm
840 g
Performance
Drive Transfer Rate
600 MBps (external)
Seek Time
12 ms (average)
Spindle Speed
7200 rpm
Reliability
MTBF
1,000,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
3.5"
Apple MacOS X 10.5 or later, Microsoft Windows Vista / 7 / 8
Limited warranty - 3 years
