Product
Brand
HGST 6TB ULTRASTAR He6 SATA 6Gb/s 64MB 3.5" Hard Drive
Quicklinx: 9GW0WS00 Mfr#: 0F18335
HGST delivers the world's first hermetically sealed, helium hard drive, the Ultrastar He6 for massive scale-out environments. Why does helium make a difference? Helium has only one-seventh the density of air. Replacing air with helium inside a hard drive dramatically reduces the turbulence caused by the spinning disk, cuts power consumption and results in a lower temperature within the disk drive.
The reduction in turbulence for the spinning disk allows HGST to offer a seven-disk design in a traditional 3.5-inch form factor. In addition to being the world's first helium-filled hard drive, HGST Ultrastar He6 is also the first hard drive in the industry to offer a 6-terabyte capacity. This design delivers a 50% capacity gain and still reduces the energy needed to run the drive by up to 23%.
HGST Ultrastar He6 HUS726060ALA640 - hard drive - 6 TB - SATA 6Gb/s
Hard drive - internal
6 TB
3.5" x 1/3H
SATA 6Gb/s
HelioSeal, 7Stac, TCOptimized
101.6 mm x 147 mm x 26.1 mm
640 g
Microsoft Certification
Compatible with Windows 7
5 years warranty
6 TB
3.5" x 1/3H
SATA 6Gb/s
101.6 mm
147 mm
26.1 mm
640 g
Reliability
MTBF
2,000,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
3.5" x 1/3H
Power Consumption
5.3 Watt (idle)
Limited warranty - 5 years
