HGST 2.5 500GB SATA3 Travelstar Hard Drive 5400RPM 16MB Cache 7mm
Quicklinx: CJ57WS00 Mfr#: 1W10013
Ideal for use as primary storage in notebooks and external enclosures, the Travelstar Z5K500.B delivers the right mix of capacity, performance and low power consumption in thin and light mobile applications. This 7 mm 2.5-inch mobile drive supports slim mobile system designs and is also compatible with most standard 9.5 mm bays. With an operational speed of 5400 RPM, the Z5K500.B is a perfect mainstream storage choice for mobile devices, external storage and gaming consoles.
HGST Travelstar Z5K500.B HTS545050B7E660 - hard drive - SATA 6Gb/s
Hard drive - internal
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
16 MB
Spindle Speed
5400 rpm
Advanced Format technology
7 cm x 10 cm x 7 mm
92 g
Warranty
3 years
2.5"
SATA 6Gb/s
Buffer Size
16 MB
Bytes per Sector
4000
7 cm
10 cm
7 mm
92 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
147 MBps
Seek Time
11 ms (average)
Average Latency
5.5 ms
Spindle Speed
5400 rpm
Reliability
Load / Unload Cycles
600,000
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5"
Power Consumption
1.4 Watt (read) , 1.4 Watt (write) , 0.55 Watt (low power idle) , 0.16 Watt (stand by) , 1.6 Watt (seek) , 5 Watt (start) , 0.16 Watt (sleep)
Halogen-free
60 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
65 °C
Shock Tolerance (operating)
400 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
1000 g @ 2 ms half-sine pulse
