Your basket is empty
HGST 1TB Travelstar SATA 6GB/s 5400RPM 8MB 9.5mm Hard Drive
Quicklinx: 9Z4MWS00 Mfr#: 0J22413
Form Factor: 2.5" x 1/8H
Type: Hard drive
Interface Type: Serial ATA-600
Capacity: 1TB, 1TB
Spin Speed (rpm): 5400rpm
£34.29 ex VAT
£41.14 inc VAT
Express delivery Delivered on Tuesday
Travelstar 5K1000 is a 5400 RPM, 500GB/platter, 2.5-inch hard drive. This standard 9.5mm, two-disk design, intended for use in notebook PCs, external storage, gaming consoles and other mobile applications, leverages advanced format, which increases the physical sector size on hard drives from 512 bytes to 4096 (4K) bytes to increase drive capacities and improve error correction capabilities.
HGST Travelstar 5K1000 HTS541010A9E680 - hard drive - 1 TB
Hard drive - internal
1 TB
2.5" x 1/8H
Data Transfer Rate
600 MBps
Buffer Size
8 MB
Spindle Speed
5400 rpm
TrueTrack servo technology, Thermal Flyheight Control (TFC), Advanced Format technology
70 mm x 100 mm x 9.5 mm
102 g
Microsoft Certification
Compatible with Windows 7
1 TB
2.5" x 1/8H
Buffer Size
8 MB
Bytes per Sector
512
70 mm
100 mm
9.5 mm
102 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
125 MBps
Seek Time
12 ms (average) / 20 ms (max)
Track-to-Track Seek Time
1 ms
Average Latency
5.5 ms
Spindle Speed
5400 rpm
Reliability
Start / Stop Cycles
600,000
Expansion & Connectivity
1 x - 7 pin Serial ATA
Compatible Bay
2.5" x 1/8H
Halogen-free
60 °C
Shock Tolerance
225 g @ 1ms half-sine pulse (operating) / 1000 g @ 1ms half-sine pulse (non-operating)
HGST 1TB Travelstar SATA 6GB/s 5400RPM 8MB 9.5mm Hard Drive Bundle deal on HGST 1TB Travelstar SATA 6GB/s 5400RPM 8MB 9.5mm Hard Drive
£47.78
saving £7.27
Cables
Including:
C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable worth £5.33 | in stock
£36.96
saving £2.67
Type: Hard drive
Capacity: 1TB
Capacity: 1TB
Brand: HGST
Stock Status: Clearance
Price Range Ex VAT: 0 - 50
