This full-featured wireless speaker is made for riders, dust- and immersion-resistant, oceanproof and featuring a built-in FM radio. It is the perfect companion for hitting the waves and the slopes, training sessions, or just kicking back and relaxing - great for surfing, standup paddleboarding, snowboarding and much more.
Immersion-resistant
This wireless speaker is able to withstand being submerged, it is dust-, sand- and snow-resistant with shock-absorbing rubber bumpers. It is the perfect companion for hitting the waves and the slopes, training sessions, or just kicking back and relaxing - great for surfing, standup paddleboarding, snowboarding and much more. -
Enjoy non-stop music, thanks to the built-in FM radio, even without your smartphone
Easily find and tune in to radio stations in your vicinity, no matter where you are in the world. The FM radio works independently of your phone, allowing you to leave it in a safe place when necessary - keep listening to your music, even in risky and wet conditions. -
Oceanproof
The speaker's grilles are specially treated to protect them against corrosion by salty seawater, via a nickel electroplating process. The speaker floats, making it easy to retrieve if dropped in the water. -
Powerful and rock-solid
The speaker's power and sound quality in outdoor conditions will blow you away - despite its compact and highly-portable design. Enjoy excellent bass response, plus clear mids and trebles. -
Built-in rechargeable battery
It features many hours of battery life. The speaker also lets you use all of its power to charge your phone if its battery is weak in an emergency situation. The speaker's built-in USB connector lets you charge a mobile phone or smartphone.
- Hercules WAE Outdoor Rush - speaker - for portable use - wireless
- Product Type
- Speaker - for portable use
- FM radio
- Protection
- Shockproof, dustproof, waterproof, snowproof, sandproof
- Speaker Type
- Active
- Continuous Power
- 4 Watt
- Peak Power
- 8 Watt
- Frequency Response
- 130 - 20000 Hz
- Amplifier
- Integrated
- Bluetooth
- Speaker Details
- Speaker - stereo x 2 - 2 Watt - 130 - 20000 Hz - active
- Power Options
- USB charging
- Battery
- Speaker battery rechargeable - Lithium Ion
- 6.5 cm x 5.7 cm x 16.5 cm
- 320 g
- Product Type
- FM radio
- Protection
Speaker System
- Speaker Type
- Active
- Continuous Power
- 4 Watt
- Peak Power
- 8 Watt
- 130 - 20000 Hz
- Magnetic Shield
- Amplifier
- Integrated
- Bluetooth 3.0
- Bluetooth Profiles
- Advanced Audio Distribution Profile (A2DP)
- Controls
- Power on/off, volume, play/pause, next track, previous track, activate Bluetooth
Speaker System Details
- Speaker Details
- Speaker - stereo x 2 - 2 Watt - 130 - 20000 Hz CFR - active
- Connector Type
- Audio line-in (mini-phone stereo 3.5 mm) , DC power output (4 pin USB Type A (power only))
- Included Accessories
- Wrist strap, USB charging cable
- Power Source
- Battery
- Options
- USB charging
- Rechargeable - Lithium Ion
- Capacity (Ah)
- 1800 mAh
- Run Time (Up To)
- 12 hour(s)
- 6.5 cm
- 5.7 cm
- 16.5 cm
- 320 g
