Hercules WAE Outdoor BTP04 Adventure Pack - Wireless Outdoor Bluetooth Speaker
Quicklinx: 8QX5WS00 Mfr#: 4780549
WATER- AND DUST-RESISTANT
Because outdoor sports and adventures are even more fun with a soundtrack of your favorite music... The Outdoor BTP04 lets all sports fans and adventure-seekers stream music from their smartphone featuring the Bluetooth® wireless technology, anywhere outdoors. IP64-certified, with the BTP04 you don't need to worry about water sprays or snow, and it even provides total protection against dust and sand as well. It's perfect for amateur or pro skiers and snowboarders, BMX riders, mountain bikers, hikers, Parkour fans and more!
WIRELESS
The BTP04 features Bluetooth® wireless technology, providing a range of up to 10 meters (depending on your environment and listening conditions). Thanks to its built-in mic, it also includes a hands-free calling function: take a call, and then pick up listening to your music right where you left off. It couldn't be easier!
ACCESSORIES
The BTP04 includes a USB cable, snap hook, wrist-strap and protective pouch, and is also available in a version with accessories that will let you enjoy the ultimate in sports adventures with your favorite music! A car cigarette-lighter charger, bike mount, suction cup mount and backpack attachment clip are also included in a special WAE OUTDOOR BTP04 ADVENTURE PACK (search 8QX5 in the searchbox for this product).
BATTERY LIFE
The BTP04 is powered by a battery providing more than 14 hours of playback time at 80% volume. Your music will follow you everywhere, throughout a full day of sporting fun!
MINI-SIZED and IMPACT-RESISTANT
At just 280 grams and 15 cm wide, it's the perfect companion for all your sports activities. Its rubber end-pieces and double protective grille provide enhanced impact resistance. Despite its small size, it provides accurate sound quality. For even more output power, you can connect multiple BTP04 speakers to one another for joint playback.
MUSIC REMOTE
More comprehensive than any remote control, the WAE application enables you to manage your OUTDOOR BTP04 easily. Listening to music becomes nothing but pure pleasure. Every time this application is launched on AndroidTM, it automatically activates the smartphone's Bluetooth® connection, which then automatically connects to the speaker.
Hercules BTP04 Adventure Pack - speaker - for portable use - wireless
Speaker - for portable use
Protection
Waterproof
Speaker Type
Active
Nominal Output Power (Total)
4 Watt
Audio System Peak Power (Total)
8 Watt
Frequency Response
130 - 20000 Hz
Amplifier
Integrated
Bluetooth
Speaker System Details
1 x speaker 4 Watt - 130 - 20000 Hz
Speaker Details
Speaker - stereo x 2 - 2 Watt - active
Speaker battery rechargeable - Lithium Ion
15.1 cm x 6.1 cm x 6.1 cm
280 g
Hands-Free Function
Protection
Waterproof
Speaker System
Speaker Type
Active
Audio System Continuous Power (Total)
4 Watt
8 Watt
Frequency Response
130 - 20000 Hz
Magnetic Shield
Amplifier
Integrated
Bluetooth 2.1 EDR
Bluetooth Profiles
Advanced Audio Distribution Profile (A2DP)
Additional Features
Built-in microphone
Speakers Included
1 x speaker - 4 Watt - 130 - 20000 Hz - wireless
Speaker Details
Connector Type
USB
Car power adapter, carrying pouch, audio cable, wrist strap, backpack clip, USB charging cable, suction cup mount, universal bike mount, large carrying bag
Power Source
Rechargeable - Lithium Ion
Capacity (Ah)
1200 mAh
Run Time (Up To)
14 hour(s)
15.1 cm
6.1 cm
6.1 cm
280 g
