Made for Riders!
- Super-tough bike mount: designed to withstand intense vibrations.
- Backpack attachment clip: specially created for extreme use
- Clear, very powerful sound for optimal listening in outdoor conditions: single-unit 2.0 speaker + passive decompression driver.
- IP66-certified: protected against powerful water jets, and totally protected against dust, sand and mud.
- Shock-resistant: reinforced rubber end-pieces.
- Standard-size screw thread, for secure attachment of the included accessories or any other standard attachment system.
- Bluetooth® 3.0 A2DP wireless technology: compatible with Bluetooth® devices.
- More than 12 hours of battery life.
- Lets you connect two Bluetooth® audio sources at the same time, and switch from one to the other quickly and easily.
- Handy control buttons: volume + and -, next and previous tracks, pause and play.
- On/off switch and auxiliary line input.
- USB charging cable included: compatible with 5 V micro-USB chargers.
- Secure tether hook for wrist strap.
- Custom Android and iOS app for smartphones.
- Hercules WAE Outdoor 04Plus pack - speaker - for portable use - wireless
- Product Type
- Speaker - for portable use
- Protection
- Shockproof, dustproof, splashproof, sandproof
- Speaker Type
- Active
- Continuous Power
- 5 Watt
- Peak Power
- 10 Watt
- Frequency Response
- 130 - 20000 Hz
- Amplifier
- Integrated
- Bluetooth
- Speaker Details
- Speaker - stereo x 2 - 2.5 Watt - 130 - 20000 Hz - active
- Power Options
- USB charging
- Battery
- Speaker battery rechargeable - Lithium Ion
- 15.1 cm x 6.1 cm x 6.1 cm
- 280 g
- 2-year warranty
- Product Type
- Protection
Speaker System
- Speaker Type
- Active
- Continuous Power
- 5 Watt
- Peak Power
- 10 Watt
- 130 - 20000 Hz
- Magnetic Shield
- Amplifier
- Integrated
- Bluetooth 3.0
- Bluetooth Profiles
- Advanced Audio Distribution Profile (A2DP)
- Controls
- Power on/off, volume, play/pause, next track, previous track
Speaker System Details
- Speaker Details
- Speaker - stereo x 2 - 2.5 Watt - 130 - 20000 Hz CFR - active
- Connector Type
- Audio line-in (mini-phone stereo 3.5 mm)
- Included Accessories
- Wrist strap, backpack clip, USB charging cable, bike mount
- IP66
- Power Source
- Battery
- Options
- USB charging
- Rechargeable - Lithium Ion
- Capacity (Ah)
- 1500 mAh
- Run Time (Up To)
- 12 hour(s)
- 15.1 cm
- 6.1 cm
- 6.1 cm
- 280 g
- Limited warranty - 2 years
