The speaker's sound quality benefits from Hercules' extensive audio expertise. The challenge met by Hercules' R&D team was to create a speaker that could deliver powerful sound, while consuming as little electricity as possible, in order to optimize battery life.
Amplification was therefore the key point in developing this solution, which goes above and beyond what had been thought possible: the Hercules WAE portable speaker BTP02 delivers up to 25 W peak power output, and consumes only 60 mW at 73 dB(C) SPL.
Music? Never without my smartphone!
Stream your music from all your Apple® devices featuring the wireless Bluetooth® technology (and your smartphone, tablet and computer).
WIRELESS
The BTP02 speaker uses the wireless Bluetooth® technology, offering a 15-metre (50') range. You can take it with you everywhere inside your home - the music never stops.
Ergonomic grip
Thanks to the device's grip, you can take your music with you everywhere.
Record-breaking battery autonomy
Enjoy your music non-stop for 20 hours. Fewer charges, more listening. 20 hours' autonomy at 73 dB (SPL @ 1 m)
Pure stereo sound
An elegant 2.0 system that will flatter your eyes and ears. Its built-in equaliser feature offers exceptional bass sounds, combined with sharp and pure sound. With 25 W, the speaker also boasts ample power.
AUX input
The speaker features a 3.5 mm mini-jack input, enabling you to connect it to your MP3 player or any other music device.
- Hercules Wireless Audio Experience BTP02 - speaker - for portable use - wireless
- Product Type
- Speaker - for portable use
- Speaker Type
- Active
- Audio System Peak Power (Total)
- 25 Watt
- Frequency Response
- 50 - 20000 Hz
- Amplifier
- Integrated
- Bluetooth
- Black
- Battery
- Speaker battery rechargeable - lithium polymer
- 23.6 cm x 17.1 cm x 24.9 cm
- Product Type
- Enclosure Colour
- Black
Speaker System
- Speaker Type
- Active
- 25 Watt
- 50 - 20000 Hz
- Amplifier
- Integrated
- Bluetooth 3.0
- Transmission Range
- 10 m
- Connector Type
- Audio input (mini-phone stereo 3.5 mm)
- Included Accessories
- AC power adaptor
- Power Source
- Battery
- Rechargeable - lithium polymer
- Run Time (Up To)
- 20 hour(s)
- 23.6 cm
- 17.1 cm
- 24.9 cm
