Your basket is empty
Hercules DJ Console 4-MX
Quicklinx: 8S6BWS00 Mfr#: 4780653
Large DJ controller with metal casing, built-in audio and large jog wheels
Large DJ station for mobile computer DJs
- 2-deck/4-deck metal DJ controller to mix 2 or 4 stereo audio tracks
- 2 stereo out (for mixing & previewing) + 2 stereo in (for analog gear)
- Mobile metal controller: a large mixer (40x25cm) with included carry bag
2 large jog wheels with touch detection
- Jog wheel size: 12cm diameter (4.7") x 1.9cm height (0.75")
- Weight sensors, to detect the hand's weight on the jog wheel top
- Great for scratching and seeking within audio tracks
2-deck & 4-deck control
2 shift buttons to turn deck A into deck C, and deck B into deck D
- 2-deck for standard DJ mixes, when mixing 2 audio tracks
- 4-deck mixing: double the controls when you mix 4 tracks
VIRTUAL DJ7 LE included: 4-deck DJ mixing software
- For Windows XP/Vista/7
- For Mac OS® 10.5 & 10.6
Hercules DJ Console 4-Mx - DJ controller - 4-channel
Headphones Output
Mic Channels
1 mono
Line Channels
2 stereo
Mic Preamplifier Gain Level
34 dB
40 cm 25 cm
DJ controller
Mixer
Channels Qty (for SD)
4-channel
Control Types
Knobs, faders
Headphones Output
Software Included
Virtual DJ 7 LE
MS Windows XP, MS Windows 7, MS Windows Vista, Apple Mac OS X 10.5 - 10.6
Headphone output volume control, USB interface, bass & treble control, 2-deck / 4-deck control, ground lift switch
Channel Description
Mic Channels
1 mono
Mic Channels Connector
Phone stereo 6.3 mm
Line Channels
2 stereo
Line Channels Connector
RCA x 2
34 dB
EQ Band Qty
3
Connector Type
1 x USB , 2 x audio line-in (RCA x 2) , 2 x audio line-out (RCA x 2) , 2 x audio line-out (phone stereo 6.3 mm x 2) , 1 x headphones - front , 1 x headphones - top , 1 x microphone - front , 1 x microphone - top
40 cm
25 cm
