Monitor and Control your home using reliable Z-Wave technology
Hauppauge mySmarthome is the easiest, most versatile solution to turn your home into a smart home. mySmarthome is reliable and secure, and can save energy by controlling lights and heat in your home. And with our cloud based alert system, you’ll know when something happens in your home. Monitor windows, doors, temperature and illumination
- Turn on/off lights and other electrical devices from your smartphone or PC
- Compatible with hundreds of different Z-Wave monitor and control devices
- Get alerts when motion is detected through the mySmarthome cloud system
- Opens endless possibilities to control and secure your home
Use your smartphone or tablet to monitor your home
Hauppauge mySmarthome comes with free iOS and Android applications. Designed to be simple to use, the mySmarthome application allows you to monitor motion, measure temperature, brightness as well as lets you switch on and off your electronic devices around your home. The application allows you to control wirelessly your home appliances and electronics. Whether you want to turn on a light in your home from your office or switch on the kettle in the kitchen it is all now possible directly from any Apple or Android Smartphone or Tablet.
Do-it-yourself Home Automation with mySmarthome
Hauppauge mySmarthome is easy to install: Connect the mySmarthome base station to your Internet router, then register for the mySmarthome cloud service. Once you've registered with the mySmarthome cloud service, add your mySmarthome control and monitor devices. Then create Rules or Scenes to automate your home. Rules tell mySmarthome what to do when something in your house happens. Scenes allows mySmarthome to control groups of lights with one button. Monitor mySmarthome sensors or run Scenes with the mySmarthome Apple or Android apps.
Create mySmarthome Rules to automate your home
Rules are the smarts behind mySmarthome. Rules let you turn on lights when a door is opened, turn on a fan when the temperature is too hot or send an e-mail message when your front door opens. Rules are powerful tools which make it easy to automate your home.
Create mySmarthome Scenes for one-click control over groups of lights
Scenes allow you to turn on or off groups of lights with one click on your iPhone or Android device. Create a scene called 'All lights on' or 'All light off' to turn all of your mySmarthome controlled lights on or off with one click on your iPhone.
- Hauppauge mySmarthome Plugs - smart plug - Z-Wave
- Product Type
- Smart plug
- Connectivity
- Wireless - Z-Wave
- Supported Host Device OS
- iOS, Android
- Localisation
- United Kingdom
- Product Type
- Smart plug
- Connectivity Technology
- Wireless - Z-Wave
- iOS, Android
- Up to 3000 Watt
- Localisation
- United Kingdom
