Product
Brand
Hauppauge myPhoto Bluetooth keyring fob mySELFIE Remote Camera Trigger
Quicklinx: B42YWS00 Mfr#: 01525
myPhoto is a portable wireless bluetooth remote controller for your iPhone, iPad and Android smartphone or tablet camera. myPhoto is small enough to fit in your pocket and carry around with you at all times doubling up as a key ring.
myPhoto also works as an anti-theft key ring so you can use one button to find your Apple or Android device and another button to locate your keys.
The ultra-compact device doubles up as a key ring. The application senses when your keys and smartphone or tablet are separated and sets off an alarm. Press the ergonomic button on the myPhoto device and your smartphone or tablet will set off an alarm. Vice versa, press the icon button from the application and an alarm will be set off from your myPhoto device attached to your keys.
Hauppauge myPhoto 1525 - mobile devices camera remote control
Mobile devices camera remote control
Wireless Technology
Bluetooth
Buttons Qty
3 buttons
1 CR2032
Wireless Technology
Bluetooth
Buttons Qty
3 buttons
Buzzer
Operating System
MS Windows 7, Apple Mac OS X 10.6, iOS 6.0, Android 4.0.3
CR2032 battery
1 CR2032
