Hauppauge HD PVR Rocket
Sale Price - Was £129.98
Quicklinx: 93BBWS00 Mfr#: 01527
Type: Video capture adapter
Compatibility: Game console, PC
Interface: USB 2.0
Hurry, only 3 left in stock!
£95.00 ex VAT
£114.00 inc VAT
HD PVR Rocket: carry a personal HD video recorder in your pocket!
HD PVR Rocket is portable and USB bus powered. Record your best game play at gaming events or at your friends home. Simply plug a USB thumb drive into the slot on the front of the Rocket and you can start recording from your games console or PC.
HD PVR Rocket records video at up to 1080p and can record from either HDMI (without HDCP protection) or Component Video.
Record your game commentary too!
HD PVR Rocket has a build-in audio mixer, so you can record game commentary while you record your video game play.
Make your own YouTube channel and share your best game play with your friends
Once you have made your recordings, you can share them with your friends on YouTube. Make your own YouTube channel and get famous!
Amazing HD audio and video quality
HD PVR Rocket records at resolutions up to 1080P30 using H.264 video compression. The H.264 format is used by Blu-ray discs and exceeds other video compression standards in quality and disk space consumption, providing a crisp image and amazing digital sound. H.264 uses 1/3 the disk space compared with the popular MPEG-2 format.
Also connect to your PC and use Hauppauge Capture to make game recordings
HD PVR Rocket also can be connected to your PC. Use our Capture application to record game play, trim your videos and upload them to YouTube.
HD PVR Rocket for PC gamers: your personal HD recorder for your game play
Record your best gaming moves without slowing down your PC. The video compression is done inside HD PVR Rocket so you can record your PC game play in HD without slowing down your PC. Simply plug the HDMI out from your PC gaming system into the HD PVR 2, and then connect HD PVR Rocket to your TV monitor.
Key Features
Pocket sized, stand alone video recorder. With built-in microphone mixer for recording game commentary
Record Xbox, PlayStation and PC games
USB powered for portable recording
Also supports PC connect mode for recording and uploading to YouTube
  • Record your game commentary too!
  • Make your own YouTube channel and share your best game play with your friends
  • Amazing HD audio and video quality
  • Also connect to your PC and use Hauppauge Capture to make game recordings
    HD PVR Rocket also can be connected to your PC. Use capture application to record game play, trim your videos and upload them to YouTube.
  • HD PVR Rocket for PC gamers: your personal HD recorder for your game play
Hauppauge HD PVR Rocket - video capture adapter - USB 2.0
Interface Type
USB 2.0
12.1 cm x 8.89 cm x 3.81 cm
130 g
English
Video Input
S-video input, USB 2.0, HDMI input, HDMI output
Analogue video Signal
S-Video
Digital Video Format
AVCHD, H.264
Audio Input Support
Standard
Interface Type
USB 2.0
12.1 cm
8.89 cm
3.81 cm
130 g
English
Video
Interface Type
S-Video
AVCHD, H.264
Audio Input Support
Standard
1 x display / video - S-video input - 4 pin mini-DIN - rear , 1 x display / video - HDMI input - 19 pin HDMI Type A - rear , 1 x display / video - HDMI output - 19 pin HDMI Type A - rear , 1 x USB - 4 pin USB Type B - rear , 1 x microphone - mini-phone stereo 3.5 mm - front , 1 x USB - 4 pin USB Type A
1 x HDMI cable - external - 2 m , 1 x USB power splitter cable - external
Compatibility: PC
Interface: USB 2.0
Brand: Hauppauge
Price Range Ex VAT: 50 - 100
