Hauppauge Colossus HD Card
Quicklinx: 7KRPWS00 Mfr#: 01412
Record your high definition video gameplay and TV programs using H.264!
Colossus is a High Definition video recorder for making real-time H.264 compressed recordings at resolutions up to 1080i.
HD PVR records component video (YCrCb) from video game consoles and cable TV and satellite set top boxes, with a built-in IR blaster to automatically change TV channels for scheduled recordings.
Colossus also has an HDMI input port, so you can record HD video at up to 1080i from a un-encrypted HDMI source.
Note: most cable and satellite TV set top boxes encrypt HDMI output, so you cannot record from these sources.
Audio is recorded using two channel stereo or optical audio with five channel Dolby Digital.
The recording format is AVCHD, which can be used to burn Blu-ray DVD disks. Two hours of HD recordings, recorded at 5 Mbits/sec, can be burnt onto a standard 4.7 GByte DVD-R or DVD-RW disk for playback on a Blu-ray DVD player.
Record your video game play
One of the popular uses for the Colossus is for recording video gameplay. As said on GeekTonic:
"Now I think anyone watching me play videogames is a sure-fire way to put them to sleep - or at least laugh at my videogame performance. But I know there is a very large number of videogamers using the HD-PVR to record their video gameplay."
Create your own HD video library ... burn your video recordings in a high definition blu-ray format! The Colossuss amazing recording quality allows personal archival of your favorite TV programs. Record your TV programs in HD, then burn them onto a standard DVD disk (up to two hours) in a high definition AVCHD fomat.
Colossus connects to any component video equipped HD set top box. Colossus also has standard definition composite input so you can record your old home video tapes and then burn onto a DVD disk. (S-Video input available with optional cable.)
Turn your old home video tapes into Blu-ray DVD disks
You can also use Colossus to turn your old VCR tapes into Blu-ray disks. Record your video tapes using Colossus and then burn Blu-ray formatted DVD disks on your PC.
Colossus has these features:
Record high definition video using H.264 video encoding with digital audio.
Colossus is an internal PCI Express board, full height, and runs with Windows 7, Windows Vista and Windows XP.
Includes a built-in high quality hardware H.264 high definition encoder, for high performance, high quality video recordingsRecord high definition video at up to 1080i resolution.
Also records standard definition video.
Record at datarates from 1Mbs to 20Mbs.
Record your game play in HD (up to 1080i) with component video and digital audio (optical) from Xbox360 or PS3 game consoles.
Record your favorite TV programs from HD cable TV and satellite set top boxes.
Colossus connects to most HD cable TV and satellite TV receivers with component video and optical digital audio.
Stereo audio inputs are supported, too.
Burn your video game play or your favorite TV programs onto AVCHD disks in high definition using standard DVD media.
These AVCHD disks can be played back on a blu-ray DVD player.
Up to 2 hours of HD AVCHD video can be recorded on standard DVD-R disks at 5MBits/sec.
Create HD recordings which can be played back on the Xbox 360 and PS3
Includes Hauppauge's WinTV v7 TV application for automatic recording of TV programs from cable or satellite set top boxes
Includes Arcsoft ShowBiz to record video game play.
Burn HD disks or upload video game play in HD to YouTube
Colossus has component video plus stereo and digital audio pass through, to allow HD recording and viewing at the same time.
NTSC and PAL support
HDMI input port included
If you have an un-encrypted HDMI video source, such as a digital SLR, you can record directly from this source.
Note: most cable and satellite TV receivers do not support un-encrypted HDMI video.Includes IR blaster and IR receiver/learn cable. Colossus can "learn" your cable TV or satellite remote control and can automatically change the channel on your set top box.
ColossusModel numbers:model 01412:
Colossus with WinTV v7 and Arcsoft ShowBiz applications.
Included with Colossus models 1412:Colossus PCI Express full height boardHauppauge remote controlA/V cable adapters (two sets supplied)Component video cable setIR blaster/receiver cableInstallation software on CD:
WinTV v7 and Arcsoft ShowBiz applications Quick Installation Guide
Colossus Specifications
Hardware encoder H.264 AVCHD video encoder
AC-3 recording from AC-3 sourceAAC audio encoding from PCM source
Recording datarate: from 1 to 20 Mbits/sec (user selectable in the ArcSoft ShowBiz application)
Recording format: up to 1080i from component video (YCrCb or YPrPb) NTSC: 720p60, 1080i60, 480i60, 480p60PAL: 720p50, 1080i50, 576p50, 576i50, 480p50, 480i50
Note: the video input format determines the recorded format. For example, 1080i input records at 1080i, 720P records at 720P, etc. Any other format conversions needs to be done with the MediaConvert program (supplied).NTSC or PAL supported
Note: when playing back video recordings made with the Colossus, a fast CPU and at least 256MB of graphics memory are needed.
Processor Requirements (minimum for HD playback): Dual core CPU 2.0GHz or faster
Windows 7 (32 and 64-bit), Windows Vista or Windows XP service pack 2 (32-bit)
Graphics with 256MB memory (or greater)
PCI Express x1 slot
Sound card for audio playback
CD-ROM drive for installing the Colossus software
Bundled software applications
ArcSoft "ShowBiz" for video recording and authoring and burning of your TV recordings onto a Blu-ray DVD compatible disc
Hauppauge WinTV v7 application, with support for the Hauppauge remote control and IR blasterInput and outputs
Note: video input on Component and HDMI sources is limited to 1080i
A/V cable input adapter with
Component video input
Left/ Right RCA audio input
A/V cable output adapter with loop through audio and video:Component video output
Left/ Right RCA audio output
Optical audio input and loop through output
HDMI input (Note: for use with un-encrypted HDMI video sources)
IR Blaster output
Third Party applications for ColossusFor the PC:
SageTV
MediaPortal version 1.2
MediaPortal version 1.2 now supports Colossus.
9
  • Create your own HD video library
    The Colossuss amazing recording quality allows personal archival of your favorite TV programs. Record your TV programs in HD, then burn them onto a standard DVD disk in a high definition AVCHD format.
  • Turn your old home video tapes into Blu-ray DVD disks
Hauppauge Colossus - video capture adapter - PCIe
Video capture adapter
Interface Type
PCIe
Included Input Adapter Accessories
Remote control, IR receiver
Video Input
Component video input, component video output, HDMI input
Video Modes
480p, 720p, 1080i, 480i, 576i, 576p
Analogue Video Format
NTSC, PAL
Analogue video Signal
Component video
Digital Video Format
AVCHD, H.264
Audio Input Support
Standard
Remote control
Microsoft Windows XP SP2 or later, Microsoft Windows Vista, Microsoft Windows 7 (32/64 bits)
Interface Type
PCIe
Video
Interface Type
Video Modes
NTSC, PAL
Component video
AVCHD, H.264
Audio Input Support
Standard
Remote control
1 x audio - line-out - RCA x 2 - on cable , 1 x audio - line-In - RCA x 2 - on cable , 1 x display / video - component video input - RCA x 3 - on cable , 1 x display / video - component video output - RCA x 3 - on cable , 1 x audio - SPDIF input - TOSLINK , 1 x audio - SPDIF output - TOSLINK
Compatible Slots
1 x PCI Express x1 - full-height
2 x A/V adapter - external
Software Included
ArcSoft ShowBiz, WinTV v7
System Requirements Details
Dual core processor - 2 GHz
