Features:
- 28" 16:9 LED Backlight Monitor
- 4K*2K 3840 x 2160 Resolution
- Toughened Glass - extreme rugged protection
- 5ms Fast Response Time
- Display port
- HDMI x 2, DVI-D
- Built-In Stereo Speakers
- Tilt and Wall-Mountable (VESA)
- Multi-Video Modes
- ECO Friendly
The HU282PPS utilize high performance panels to deliver true ultra high-definition resolution images. UHD, also known as 4K, offers an incredible viewable display area with 4 times more work space than Full HD screens and over 8 milion pixels.
The HANNspree HU282PPS features a hardware interface with advanced connections to maximize the usability. It provides seamless connectivity with your PC and AV equipment with DP, DVI and 2 different HDMI ports.
The HU282PPS has twin built-in 3 W speakers that provide quality audio for a completely immersive home theater experience. Built-in speakers make it easy to catch up with family, friends and colleagues.
4K ultra-high definition resolution for impeccable images
The HU282PPS utilize high performance panels to deliver true ultra high-definition resolution images. UHD, also known as 4K, offers an incredible viewable display area with 4 times more work space than Full HD screens and over 8 milion pixels. -
Extensive connectivity with triple interface
The HANNspree HU282PPS features a hardware interface with advanced connections to maximize the usability. It provides seamless connectivity with your PC and AV equipment with DP, DVI and 2 different HDMI ports. -
High speed connections
The HANNspree HU282PPS comes with high-bandwidth connection ports like HDMI 2.0, DVI and DP. -
Speakers and headphones
- HANNS.G HU282PPS - HU Series - LED monitor - 28"
- LED-backlit LCD monitor - 28"
- Energy Class
- Class B
- Energy Consumption per Year
- 55 kWh
- Power Consumption (On mode)
- 38 W
- Aspect Ratio
- 16:9
- Native Resolution
- 4K UHD (2160p) 3840 x 2160 at 60 Hz
- Pixel Pitch
- 0.16 mm
- Brightness
- 280 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 1.07 billion colours
- Input Connectors
- 2xHDMI, DVI-D, DisplayPort
- Tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- 68.01 cm x 19.2 cm x 50.41 cm
- 7.2 kg
- 3-year warranty
- Display Type
- Energy Class
- Class B
- 55 kWh
- Diagonal Size
- 28"
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.16 mm
- Brightness
- 280 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 60 - 75 Hz
- Horizontal Refresh Rate
- 30 - 80 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Screen Coating
- Anti-glare
- Backlight Technology
- WLED
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Korean
- HDCP, game mode, FPS Mode, RTS Mode
- 7.2 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 3 Watt
- DisplayPort , DVI-D , 2 x HDMI , Audio line-in , Headphones
Mechanical
- Tilt
- Tilt Angle
- -5/+15
- VESA Mounting Interface
- 75 x 75 mm
- Cables Included
- 1 x audio cable , 1 x DVI cable
- Input Voltage
- 38 W
- Power Consumption (Typical)
- 38 Watt
- Power Consumption Stand by
- 0.5 Watt
- On / Off Switch
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 0 - 70%
