- HANNS.G HZ281HPB - LCD monitor - 27.5"
- Stereo speakers
- Aspect Ratio
- 16:10
- Native Resolution
- 1920 x 1200
- Pixel Pitch
- 0.309 mm
- Brightness
- 400 cd/m²
- Contrast Ratio
- 800:1 / 15000:1 (dynamic)
- Response Time
- 3 ms (grey-to-grey), 5 ms (On/Off)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI-D, VGA
- Speakers
- Integrated
- Tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- 65.3 cm x 25.4 cm x 52.3 cm
- 8.5 kg
- Environmental Standards
- ENERGY STAR Qualified
- MPR II, UL, VCCI, cUL, CB, CCC, PSB, FCC, RoHS, cULus, GOST-R
- 3-year warranty
- Display Type
- LCD monitor / TFT active matrix
- Diagonal Size
- 27.5"
- Built-in Devices
- Stereo speakers
- Aspect Ratio
- 16:10
- Native Resolution
- 1920 x 1200
- Pixel Pitch
- 0.309 mm
- Brightness
- 400 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 75 Hz
- Horizontal Refresh Rate
- 80 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Screen Coating
- Anti-glare
- OSD Languages
- English, German, French, Italian, Norwegian, Portuguese, Russian, Spanish, Korean
- HDCP
- 8.5 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 2 Watt
- VGA , DVI-D , HDMI , Audio line-in
Mechanical
- Tilt
- Tilt Angle
- 20
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable , 1 x audio cable , 1 x HDMI-DVI cable
- Power Supply
- Internal
- Input Voltage
- Power Consumption (Typical)
- 95 Watt
- Power Consumption Stand by / Sleep
- 1 Watt
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - parts and labour - 3 years , Limited warranty - LCD panel - 1 year , Limited warranty - backlight - 1 year
- 5 °C
- 35 °C
- 10 - 85%
