HannsG 22" Wide Hard Glass LED Monitor
Quicklinx: 914TWS00 Mfr#: HP226DGB
Marketing description is not available.
HANNS.G HP226DGB - HP Series - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
220 cd/m²
Contrast Ratio
1000:1 / 30000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
51 cm x 20 cm
5.06 kg
Environmental Standards
ENERGY STAR Qualified
RoHS
Display Type
Diagonal Size
21.5"
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
220 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
31 - 83 kHz
Vertical Viewing Angle
160
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, input select, colour temperature
OSD Languages
English, German, French, Portuguese, Russian, Spanish, Dutch, Turkish, Korean
Strengthen glass
51 cm x 20 cm
5.06 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1.5 Watt
VGA , DVI-D (HDCP) , Audio line-in
Mechanical
Tilt
Tilt Angle
-5/+15
VESA Mounting Interface
100 x 100 mm
1 x audio cable - 1.8 m , 1 x VGA cable - 1.8 m
RoHS
Security Slot Type
Kensington security slot
Power Supply
Internal
Input Voltage
Power Consumption (Typical)
30 Watt
Power Consumption Stand by / Sleep
1 Watt
ENERGY STAR Certified
