Hama Tripod Star 62 including Bag - 160cm
Quicklinx: 7L82WS00 Mfr#: 00004162
Type: Tripod
£22.79 ex VAT
£27.34 inc VAT
For serious photographers a good, sturdy tripod is a must have for certain photos, preventing camera movement to minimise blurring and creating a sharp, high-quality photo. This makes them ideal to use for capturing self-portraits or group shots, where there is no one to hold the camera, as well as for slow-speed exposures or when capturing wildlife and other scenes where details need to be crisp and clear.
Become snap happy and produce beautiful professional looking shots with this versatile and ultra portable Star 62 tripod. Suitable for use with both video and photo cameras, its rubber feet permit a firm grip on a range of terrains, with an aluminium structure that creates a strong and sturdy support for cameras up to a maximum weight of 3.5kg whilst also remaining lightweight for easy and convenient transportation and great pictures on the go.
To allow you to achieve a range of heights (from 64-160cm) and to capture pictures and videos from the perfect perspective in a variety of situations, the Star 62 comes with a fully adjustable centre column which can be easily altered by using the simple crank, along with a 3-way tripod head which can be repositioned at a number of different angles and smoothly panned for the creation of a smooth and professional film. Furthermore, with its standard 1/4" (6.4mm) thread, mounting your camera no longer needs to be a chore as you can attach it to the tripod and even switch between different cameras in an instant, ensuring that you never miss that all important photo opportunity.
A fantastic piece of kit for the money, it even comes with its own travel case which it folds neatly into so that you can carry your tripod around with you safely with no hassle. Whether you are hiking up a hill, attending an important event or jetting off to your next holiday destination, you will always be fully prepared for any photographic eventuality thanks to the Star 62!
  • The 3D tilt head allows perfect alignment for landscape and portrait shots
  • Quick-release plate for quickly changing the camera
  • Spirit level integrated into the tripod head and spirit vial at the base
  • With crank for continuous height adjustment of the centre column
  • Lockable leg braces and flexible rubber feet for a firm and steady grip on uneven surfaces
  • With the functional quick-action leg locks the tripod legs can easily and quickly be fixed at the required height or position
  • Handle
  • With hook for weighing the tripod down in strong winds and on rough terrain
  • Spare quick release plate:
Hama Star 62 tripod
Tripod
160 cm
1.5 kg
Champagne
Head Type
Pan
Tripod Operating Height
64 cm - 160 cm
Max Supported Weight
4 kg
Tripod
160 cm
1.5 kg
Champagne
Material
Aluminium
Tripod
Tripod Legs Sections Qty
3
Tripod Legs Lock Type
Flip lock lever
Quick Release System
Tripod Centre Column Type
Geared
Max Operating Height
160 cm
Min Operating Height
64 cm
4 kg
Supported Devices
Camcorder, camera
Accessory hook, carry handle, leg braces
Head
Head Type
Pan
Head Positioning
3-way
Tripod Mount
1/4" screw
Case
Type: Tripod
Brand: Hama
Price Range Ex VAT: 0 - 50
