Hama MOTION TV Wall Bracket 37"- 56" - Black
Quicklinx: CVQ5WS00 Mfr#: 00108778
For the installation of flat screen TVs with a screen size from 81 cm to 142 cm (32" to 56"). Allows optimal positioning of the flat screen in every room and supports all VESA standards up to 600 x 400. 12 Degrees continuous tilt.
  • Easy-Fix system for simple and fully adjustable orientation of your TV.
  • Integrated spirit level for fast and easy mounting.
Hama MOTION TV Wall Bracket, 1 star, XL mounting kit - for TV - black
Mounting kit - wall-mountable
Mounting Components
Wall mount
22 cm x 3.5 cm x 67 cm
Adjustments
Tilt
Recommended Use
TV
Recommended Display Size
37"-56"
VESA Mounting Interface
100 x 100 mm, 200 x 200 mm, 400 x 300 mm, 400 x 200 mm, 400 x 400 mm, 600 x 400 mm, 600 x 200 mm, 300 x 200 mm, 300 x 100 mm, 200 x 100 mm, 300 x 300 mm, 600 x 300 mm, 500 x 400 mm, 200 x 300 mm, 300 x 400 mm
Material
Steel
22 cm
3.5 cm
67 cm
Material
Steel
AV Furniture
Mounting kit
Mounting Components
Wall mount
Recommended Use
TV
Placing / Mounting
Wall-mountable
37"-56"
Adjustments
Tilt
