This FULLMOTION Monitor Arm bracket allows you to adapt the position of your monitor to your needs and body posture. What is more, it helps you make more space on your desk.
- Hama FULLMOTION Monitor Arm mounting kit - adjustable arm - for Monitor - black
- Product Type
- Mounting kit (adjustable arm) - desk-mountable
- 11.5 cm x 17.3 cm x 50.8 cm
- Tilt
- -90° to 85°
- Pan
- 360°
- Rotation
- 360°
- Adjustments
- Height, pan, tilt, rotation, lift
- Recommended Use
- Monitor
- Recommended Display Size
- 10"-26"
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm
- Max Load Weight
- 10 kg
- Black
- Package Content
- Mounting hardware
- 2-year warranty
- 11.5 cm
- 17.3 cm
- 50.8 cm
- Black
- Package Content
- Mounting hardware
AV Furniture
- Mounting kit
- Design
- Adjustable arm
- Recommended Use
- Monitor
- Placing / Mounting
- Desk-mountable
- Cable Management
- Integrated cable management
- 10"-26"
- Tilt
- -90° to 85°
- Pan
- 360°
- Rotation
- 360°
- Adjustments
- Max Load Weight
- 10 kg
- Limited warranty - 2 years
