Product
Hama FULLMOTION Gas Spring Monitor Arm 26"
Quicklinx: D76YWS00 Mfr#: 00095820
  • For the installation of TFT/LCD/LED monitors with a screen diagonal of up to 66 cm (26")
  • Integrated high-performance pneumatic spring for vertical, fully adjustable orientation
  • 360° rotation for horizontal or vertical orientation
  • Swivel arms for maximum rotation
  • The retaining system keeps your workplace tidy and allows you to work ergonomically
  • Cable manager provides organisation and necessary strain relief
  • Swivel range on 3 hinges: up to 360°
  • Swivel range up to 180°
  • Inclinable +/- 90°
  • Supports all VESA standards up to 100x100
  • Table fastening with clamping screw (table top thickness up to max. 10 cm) or drill-secured mounting
Note for Consumers: To ensure that the holder is height adjustable, a minimum supported load of around 1.5 kg is required.
Technical Details: - Maximum Load: 5 kg - Model: Monitor Arm - Monitor Fixation Standart: VESA incl. Adapter Plate - Rotation Range: 360 ° - Tilt +/-: 90 / 90 ° - Adjustable Distance: Yes - Max. Monitor Size: 66 cm - VESA Standard: 100 x 100 mm - Width x Depth x Height: 11,5 x 52,2 x 11,2 cm - Colour: Black - For Monitors: 26" - For a Table Top Thickness of: 10 cm
Hama FULLMOTION - desk mount (adjustable arm)
Desk mount (adjustable arm)
11.5 cm x 52.2 cm x 11.2 cm
Tilt
-90° to 90°
Pan
360°
Rotation
360°
Adjustments
Lift
Recommended Use
Monitor
Recommended Display Size
26"
Flat Panel Mount Interface
100 x 100 mm
Max Load Weight
5 kg
Package Content
Mounting hardware
2 years warranty
11.5 cm
52.2 cm
11.2 cm
Package Content
Mounting hardware
AV Furniture
Desk mount
Design
Adjustable arm
Recommended Use
Monitor
100 x 100 mm
Cable Management
Integrated cable management
26"
Tilt
-90° to 90°
Pan
360°
Rotation
360°
Adjustments
Lift
Max Load Weight
5 kg
