The extremely flat profile of Hama's Ultraslim Fullmotion Wall Backet allows for modern and space-saving interior design. The Easy-Fix system means simple installation and fully adjustable orientation of your TV.An intergrated cable manager provides organisation and necessary strain relief.
- Hama FIX TV Wall Bracket bracket - for LCD TV - black
- Product Type
- Bracket - wall-mountable
- 22 cm x 2.3 cm x 22 cm
- Recommended Use
- LCD TV
- Recommended Display Size
- 19"-48"
- VESA Mounting Interface
- Up to 200 x 200 mm, from 50 x 50 mm
- Max Load Weight
- 25 kg
- Material
- Steel
- Black
- 2-year warranty
- 22 cm
- 2.3 cm
- 22 cm
- Material
- Steel
- Black
AV Furniture
- Bracket
- Recommended Use
- LCD TV
- Placing / Mounting
- Wall-mountable
- 19"-48"
- Max Load Weight
- 25 kg
Dimensions & Weight Details
- Dimensions
- Plate - width: 22.9 cm height: 9.6 cm
- Limited warranty - 2 years
