Hama CD/DVD/Blu-ray Wallet Black
Quicklinx: D1SZWS00 Mfr#: 00033830
The Hama wallet for storing CD, DVD and Blue-ray, it has 20 high quality anti-static sleeves.
Hama CD Wallet Nylon 20 - wallet for CD/DVD discs
Wallet for CD/DVD discs
16.4 cm x 16.6 cm x 4.5 cm
Supported Media Qty
20 discs
Material
Nylon
16.4 cm
16.6 cm
4.5 cm
Material
Nylon
Carrying Case
Wallet
Recommended Use
For CD/DVD discs
Carrying Strap
Hand strap
Closure Type
Zipper
Supported Media Qty
20 discs
Foam padding
