Hama Black Desire PC Headphones
Quicklinx: CVQ9WS00 Mfr#: 00053984
Recommended Use: Computer, Portable electronics
Connectivity: Wired
46 in stock
£15.71 ex VAT
£18.85 inc VAT
This PC headset leaves nothing to be desired since it is very versatile. You can use it on a PC and notebook in combination with an adapter, on a controller or smartphone with a standard cable and with or without microphone - everything is possible. Let the games begin!
  • The included 3-pin adapter allows you to connect a PC and notebook.
  • Padded over-ear ear cushions and headband for a comfortable fit also over longer periods of time. #
  • Mute button allows users to switch the sound off on the microphone quickly.
  • Flexible, removable 360° microphone arm for optimal positioning.
Hama "Black Desire" - headphones with mic
Headphones - wired - 3.5 mm jack
Recommended Use
Portable electronics, computer
Headphones Form Factor
On-ear
Wired
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 20 - 20000 Hz - Sensitivity 108 dB
Impedance
32 Ohm
Microphone
Boom
Microphone Operation Mode
Cardioid
Controls
Mute, volume
Headphones - 3.5 mm jack
Recommended Use
Headphones
Supraaural
Wired
Sound Output Mode
Stereo
Frequency Response
20 - 20000 Hz
Sensitivity
108 dB
Impedance
32 Ohm
Diaphragm
40 mm
In-Cord Volume Control
Adjustable Headband
Microphone
Boom
Cardioid
Sensitivity
-58 dB
Impedance
10 kOhm
Frequency Response
30 - 15000 Hz
Remote Control
Controls
Mute, volume
Connector Type
Headphones (mini-phone stereo 3.5 mm x 2)
Cable
Cable Length
1.8 m
Plated Connector
Gold
Headphones cable - 1.8 m
2 x 3.5mm jack adapter
Recommended Use: Portable electronics
Connectivity: Wired
Brand: Hama
Price Range Ex VAT: 0 - 50
