The Hama "Slim" multi card reader allows for the fast transfer of data with speeds up to 5Gbit/s abd USB 3.0 compatibility. It supports lots of memory card formats including SD/microSD/CF/MS.
- Hama "Slim" USB 3.0 SuperSpeed Multi Card Reader - card reader - USB 3.0
- Product Type
- Card reader - external
- Supported Memory Cards
- CompactFlash Card type I, CompactFlash Card type II, Memory Stick, Memory Stick PRO, Microdrive, MultiMediaCard, SD Memory Card, miniSD, MultiMediaCardmobile, microSD, MultiMediaCardplus, MultiMediaCardmicro, SDHC Memory Card, miniSDHC, microSDHC, SDXC Memory Card, microSDXC
- Host Interface
- USB 3.0
- Black
- 2-year warranty
- Product Type
- Host Interface
- USB 3.0
- Black
- 90 mm
- 50 mm
- 9 mm
- 70 g
Memory Card
- Capacity
- (max)
- Required Ports
- 1 x 9 pin USB Type A
- OS Required
- Microsoft Windows Vista / XP / 7
- Included Accessories
- USB cable
- Limited warranty - 2 years
