The Hama "Kids" On-Ear Headphones are perfect for children's sensitive ears, protecting them with a volume limitation to max. 85 dB according to EN 71-1 standard. The foam earpads ensure a comfortable fit.
- Hama "Kids" - headphones
- Product Type
- Headphones - wired - 3.5 mm jack
- Recommended Use
- Portable electronics
- Purple, rose
- Headphones Form Factor
- On-ear
- Connectivity Technology
- Wired
- Sound Output Mode
- Stereo
- Audio Specifications
- Frequency Response 20 - 20000 Hz - Sensitivity 85 dB/mW
- Impedance
- 32 Ohm
- 2-year warranty
- Product Type
- Purple, rose
- Body Material
- Plastic
- Recommended Use
Audio Output
- On-ear
- Wired
- Sound Output Mode
- Stereo
- 20 - 20000 Hz
- Sensitivity
- 85 dB/mW
- Impedance
- 32 Ohm
- Diaphragm
- 30 mm
- Adjustable Headband
- Connector Type
- Headphones (mini-phone stereo 3.5 mm)
Cable
- Plated Connector
- Gold
- Cable Details
- Headphones cable - 1.2 m
- Limited warranty - 2 years
