Guardzilla All-in-One HD Video Security System - Black
Quicklinx: D3PHWS00 Mfr#: GZ621B
Guardzilla® All-In-One HD Video Security System
Our original Guardzilla is an easy-to-use video security system that lets you monitor your home and deter intruders with your smartphone from wherever you are. It features crystal clear HD video, a 100 db siren, night vision, and much more.
Product Features
• Live HD video viewable from anywhere via your smartphone
• Motion sensors capture movement and trigger smartphone alerts
• 100dB siren alert
• Email, text and/or push notifications sent to your smartphone
• Two-way audio
• Infrared night vision
• Wide angle lens
• No installation, free app sets up in 5 minutes
• No monthly fees
• Syncs with an iPhone & Android app
• Cloud storage of motion events
• Option to record video with SD card (sold separately)
• Wi-fi enabled
• Multi-unit and multi-user home solution
• Support for Apple and Android
• 1 year limited warranty
Security Made Simple
Whether you choose to protect and monitor your home’s interior or exterior, Guardzilla offers the easiest-to-use app on the market.
Arm/Disarm
Arm and disarm your system for motion detection (and the 100 dB siren) with the push of a button. Auto-arming is available for automatic arming/disarming.
Monitor
Monitor live HD video and take images from your smartphone. Broadcast into the room and listen in.
Event History
All motion events are captured in 5-second video clips and retained for two days for free. Cloud storage options provide longer video retention options.
Settings
Settings lets you choose your phone notification preference (text, email, push) when motion is detected, and much more.
Panic
The Panic button gives you the option of sounding the 100 dB siren.
Camera List
Camera List lets you add more Guardzilla security cameras.
Three Quick Steps to Set Up Your Guardzilla
1. Plug in your Guardzilla: NO HUB REQUIRED!
2. Download our app to your iPhone or Android smartphone.
3. Connect Guardzilla to your home Wi-Fi and customize your settings.
You’re now ready to protect and monitor your home with Guardzilla
  • HD video
    Watch live, 720p high-def video on your smartphone from wherever you are.
  • Built-in speaker and microphone
    Listen in and broadcast into the room.
  • Night vision
    Infrared sensors provide video images in dark areas.
  • Motion detection
    Precision motion sensors capture movement and send smartphone alerts (text, push or email).
  • Cloud storage
    Store video recordings of motion events and download to your phone.
  • Auto-arm
    Can be set to automatically arm when leaving home and disarm when returning.
  • Loud siren
    Ear-splitting siren deters intruders.
  • Video recording
    Can record a few days of video with microSD card.
Guardzilla All-In-One HD Video Security System - home security system - 802.11b/g/n - black
Home security system
Functions
Siren, motion detection
Integrated Components
Microphone, speaker
Wireless - 802.11b/g/n
Siren Sound Level
100 dB
Frequency Band
2.4 Ghz
Supported Host Device OS
iOS, Android
Camera
Audio - Day&Night
11.4 cm x 7.1 cm x 14 cm
Functions
Microphone, speaker
Wireless
Frequency Band
2.4 Ghz
Siren Sound Level
100 dB
iOS, Android
Camera
Day & Night Functionality
Audio Support
Video Modes
720p
microSD card slot, 89° field of view
Motion Sensor
Detection Mode
Passive infrared (PIR)
11.4 cm
7.1 cm
14 cm
226.8 g
