Synthetic sapphire glass provides superior shatter and scratch resistance qualities. Survivor Glass protects your multi-touch display without hampering touch sensitivity or 3D Touch functions. With almost twice the scratch resistance of normal glass, Survivor Glass protects your iPhone's screen from both major, appearance-marring scratching and the micro-scratching that's not immediately visible to the naked eye. A 5-micron layer of oleophobic coating prevents smudges and grease from taking anything away from your phone's Retina display.
Sapphire glass
Synthetic sapphire glass provides superior shatter and scratch resistance qualities. Survivor Glass protects your multi-touch display without hampering touch sensitivity or 3D Touch functions. -
Unmatched screen protection
With almost twice the scratch resistance of normal glass, Survivor Glass protects your iPhone's screen from both major, appearance-marring scratching and the micro-scratching that's not immediately visible to the naked eye. A 5-micron layer of oleophobic coating prevents smudges and grease from taking anything away from your phone's Retina display. -
Reinforced edges
Survivor Glass's edges are reinforced to prevent micro-cracks that compromise the integrity of the glass itself. And Survivor Glass is backed with high-quality, micro-suction adhesive that adheres bubble-free to your phone's screen. Protect your phone's screen with Survivor Glass, the only screen protector hard enough to be called Survivor.
- Griffin Survivor Glass - screen protector for mobile phone
- Product Type
- Screen protector - glass
- Intended For
- Mobile phone
- Protection
- Shockproof, scratch-resistant
- Package Content
- Screen protector, polishing cloth, dust removal tab
- Product Material
- Sapphire glass
- 1-year warranty
- Product Type
- Intended For
- Mobile phone
- Protection
- Package Content
- Product Material
- Sapphire glass
- 1-year warranty
