Designed to deliver IP-55-rated water resistance, Summit is splash-proof, dirtproof, sandproof and rainproof. Summit's impact dispersion system absorbs impact forces, directing them away from your phone. Summit protects the display and home button with a Touch ID-compatible slide-on screen shield.
Mud resistant
Designed to deliver IP-55-rated water resistance, Summit is splash-proof, dirtproof, sandproof and rainproof. -
Impact dispersion system
Summit's impact dispersion system absorbs impact forces, directing them away from your phone. -
Screen guard
Summit protects the display and home button with a Touch ID-compatible slide-on screen shield. -
Layers of protection
Shatter-resistant multi-layer construction. Plus, your phone's controls, headphone jack, speakers and microphones are protected from debris and damage. -
Slim design
With its slim, rounded design and no-slip grip, Summit is easy to get into and out of your pocket. -
Belt clip
Rotating belt clip/video stand makes carrying and viewing easy.
- Griffin Survivor Summit - protective case for mobile phone
- Product Type
- Protective case for mobile phone
- 9.19 cm x 1.27 cm x 17.272 cm
- 79.66 g
- Material
- Silicone, polycarbonate, thermoplastic elastomer (TPE)
- Black, dark blue
- 1-year warranty
- 9.19 cm
- 1.27 cm
- 17.272 cm
- 79.66 g
- Rugged
- Material
- Black, dark blue
Carrying Case
- Protective case
- Recommended Use
- For mobile phone
- Protection
- Splashproof, dirt-resistant, impact protection, shatterproof, sandproof, drop-proof
- Carrying Strap
- Rotating belt clip
- Cover Features
- Stand function
- 1 year
