Built to deliver high durability and protection, Survivor Strong effectively protects your phone.
Protective from the inside out
Survivor Strong's dual-material snap-on shell uses Griffin's exclusive system to protect your phone within its shatter-resistant shell and keeps it safe from impacts. -
Light meets strong
There's strength in that ultra-slim profile. Tipping the scale at less than two ounces, Survivor Strong is light, but delivers heavy-duty protection. -
Strong two-layer shell
Inside, Survivor Strong surrounds your phone in a rigid, dent-preventing polycarbonate shell. Outside, a scuff-proof, sure-grip layer is easy to hold on to, but slides easily into your pocket.
- Griffin Survivor Strong - back cover for mobile phone
- Product Type
- Back cover for mobile phone
- Material
- Polycarbonate
- Clear
- 1-year warranty
- Designed For
- Apple iPhone XS Max
- Material
- Polycarbonate
- Clear
Carrying Case
- Protective cover
- Recommended Use
- For mobile phone
- Protection
- Impact protection, shatterproof, drop-proof, wear-resistant
- Cover Type
- Back cover
- MIL-STD 810G
- 1 year
- Designed For
