Griffin Survivor Slim iPad Pro 9.7"Black
Quicklinx: C3X3WS00 Mfr#: GB41875
Multi-layered drop protection in a slimmed-down form factor, the Survivor Slim is great for anyone looking for drop protection. Survivor Slim's inner, impact-resistant polycarbonate shell is jacketed in premium silicone to guard your tablet against damage from drops. A smooth, curved exterior and non-slip texturing give Survivor Slim a distinctive look that's easy to hold.
  • Rugged protection
    Designed to meet or exceed MIL-STD-810G standards for 6.6-foot drop protection on concrete, Survivor Slim's inner, impact-resistant polycarbonate shell is jacketed in premium silicone to guard your iPad against damage from drops. A smooth, curved exterior and non-slip texture give Survivor Slim a distinctive look that's easy to hold onto. The anti-scratch screen shield protects your touchscreen and Home button from scratches while keeping the sensitivity of your Multi-Touch display and Touch ID. It's the perfect blend of drop protection, screen protection, and compatibility with your Smart Keyboard.
  • Smart Keyboard and Apple Pencil compatible
    Survivor Slim is fully compatible with Apple's Smart Keyboard without removing the case, via an opening on the side. Attach your Smart Keyboard to your iPad, then pop open Survivor Slim's built-in kick-stand to position your iPad at the perfect angle for typing. The groove in the top of your Apple Smart Keyboard is a perfect place to store your Apple Pencil as you type. A snap-on storage clip holds your Apple Pencil when not in use. When you're done working, close the kickstand, flip the Smart Keyboard closed like a book cover, and you're off.
  • High-fidelity sound
    iPad has raised the bar on sound, with four stereo speakers positioned at the top and bottom of your iPad for wall-to-wall sound. Survivor Slim's four speaker ports let your iPad sound off like it's supposed to so you don't miss a thing.
Griffin Survivor Slim - protective case for tablet
Protective case for tablet
Screen Size Compatibility
9.7"
Material
Silicone, polycarbonate
1-year warranty
Rugged
Material
Carrying Case
Protective case
Recommended Use
For tablet
9.7"
Protection
Drop-proof
Screen protector, Apple Pencil Clip, magnetic Smart Keyboard adapter
Cover Features
Stand function
MIL-STD 810G
Max Height of Shock Resistance
2 m
1 year
