Griffin Survivor for iPad2/3/4 - Black
Quicklinx: 9TXGWS00 Mfr#: GB35108-3
Griffin designed and rigorously tested Survivor All-Terrain to be the most protective case possible for whatever your day has in store. Built from the inside out to meet or exceed the standards published in US Department of Defense MIL-STD-810G, Survivor All-Terrain protects your phone from extreme conditions, including drops, dust, sand, rain, impacts, vibration, and a host of other environmental factors. Survivor All-Terrain's 4 layers of protection start with a foam-lined shatter-resistant polycarbonate frame clad in rugged, shock-absorbing silicone. A built-in screen protector snaps on to seal your touchscreen from the outside environment. Volume and power buttons are covered, and hinged plugs seal the Lightning connector, headphone port, and hold switch. And, to make it easy to carry, a detachable heavy-duty rotating clip secures your phone to your belt or bag strap.
Griffin Survivor All-Terrain - protective case for tablet
Protective case for tablet
20.1 cm x 2.67 cm x 25.7 cm
431 g
Material
Silicone, polycarbonate
20.1 cm
2.67 cm
25.7 cm
431 g
Material
Carrying Case
Protective case
Recommended Use
For tablet
Protection
Splashproof, dust-resistant, sandproof, vibration-proof, drop-proof
Camera lens cutout, port cut-outs, built-in screen protector, rigid frame, Touch ID compatible
Cover Features
Stand function
MIL-STD 810F
