Griffin Survivor Case for Samsung Galaxy Tab 4 10.1" - Black/Black/Black
PRICE DROP!
Clearance
Last Few Remaining
Price Drop
Quicklinx: 9YSVWS00 Mfr#: GB39915
Ridiculously over-engineered? Or the perfect case no matter where you're headed?
Simply put, it is made to be the most protective case possible, that you can carry and use every day.
Griffin's Survivor extreme-duty case is built from the inside out to protect your Galaxy Tab from extreme conditions ... dust, sand, rain, shock, vibration and a host of other environmental factors.
Survivor is built on a shatter-resistant polycarbonate frame clad in rugged, shock-absorbing silicone. A built-in screen protector seals your touchscreen from the outside environment. Hinged plugs seal the dock connector, headphone port, switches and volume controls when you're not using them.
Griffin Survivor - protective case for tablet
Protective case for tablet
Screen Size Compatibility
10.1"
Material
Silicone, polycarbonate
Samsung Galaxy Tab 4 (10.1 in)
Material
Carrying Case
Protective case
Recommended Use
For tablet
10.1"
Protection
Splashproof, shockproof, dust-resistant, sandproof, vibration-proof, wear-resistant
Port covers, built-in screen protector
MIL-STD 810G
