Survivor Adventure delivers unmatched style in a case that protects your iPhone 7 from 8-foot drops. Survivor Adventure packs three looks in one protective case, so your iPhone is perfectly dressed for wherever life’s adventures take you.
8-foot drop protection
Built to protect your iPhone from 8-foot (2.4 meter) drops, Adventure is designed to meet or exceed military standards for device protection (Mil-Std 810-G). The built-in Impact Dispersion System absorbs and disperses impact forces from drops before they can harm your iPhone. -
Choices, choices
Each Survivor Adventure gives you two interchangeable back plates so you can choose your look. Those two snap-on backplates also help make Survivor Adventure twice as protective as single-layer-back cases. But for those times you want to go as light as possible, you can go without either of the backplates. Survivor Adventure's all-around impact-resistant plastic shell still covers the back of your iPhone, protecting it from scratches and dents as it the case delivers 8' drop protection.
- Griffin Survivor Adventure - back cover for mobile phone
- Product Type
- Back cover for mobile phone
- Material
- Polycarbonate, thermoplastic polyurethane (TPU)
- Cherry black, bonbon glitter
- 1-year warranty
- Material
Carrying Case
- Protective cover
- Recommended Use
- For mobile phone
- Protection
- Scratch-resistant, impact protection, drop-proof
- Cover Type
- Back cover
- Included Accessories
- 2 interchangeable back plates
- MIL-STD 810G
- Max Height of Shock Resistance
- 2.4 m
- 1 year
