Save your Galaxy S8's touchscreen from scratches, dirt, oils, and smudging with Survivor Glass Screen Protectors.
                Hardened defensesThey use only high-clarity, ultra-hard tempered glass to protect your phone's screen. The glass is 9H scratch-resistance tested, so it's ready to stand up to your keys, tabletops, sand, and other abrasive conditions. At just. 33 mm thin, Survivor Glass goes on easy and practically disappears, so it works with most open-faced cases.
                Out on the edgeSurvivor Glass is kiln finished to follow your Galaxy S8+'s dual curved-edge Infinity display. No more edges to spoil the view.
                Shine onMicro-polishing brings Survivor Glass to a mirror finish that never gets in the way of your Galaxy's touchscreen, so your movies and pictures look great. A micron-thin anti-oil coating keeps fingerprints and oils from spoiling the view.
                They brought in reinforcementsSurvivor Glass' edges are reinforced to prevent micro-cracks that occur from everyday use, You can't see those cracks, but they can compromise the internal integrity of the glass itself and lead to early failure.
                Easy-on installationJust wipe down your phone's screen with the included no-lint polishing cloth, align the glass, and press it gently into place. Survivor Glass uses a high-quality, micro-suction adhesive to adhere bubble-free to your phone's screen.
- Griffin Survivor - screen protector for mobile phone
- Product Type
- Screen protector - glass
- Intended For
- Mobile phone
- Protection
- Scratch-resistant, dirt-resistant
- Product Material
- Tempered glass (9H)
- Thickness
- 0.33 mm
- 1-year warranty
- Designed For
- Samsung Galaxy S8+
- Product Type
- Intended For
- Mobile phone
- Protection
- Product Material
- Thickness
- 0.33 mm
- 1 year
- Designed For
