Say hello to safe, rapid wireless charging that’s Guaranteed for Life.
PowerBlock Wireless Charging Pad is the perfect charger for the cord-weary device user. Compatible with any Qi-enabled device, PowerBlock Wireless Charging Pad offers worry-free rapid charging when and where you need it—without the cables.
15 Watts of Rapid Charging Power
Think wireless charging has to be slow? Think again. The PowerBlock Wireless Charging Base safely and easily charges your Qi-enabled devices up to 3X faster than standard 5W wireless chargers.
Effortless Charging, Every Time
To charge your Qi-enabled device with The PowerBlock Wireless Charging Pad, all you have to do is sit your phone on the no-scratch, felted platform. That’s it. No cords, no plugs, no fuss.
LED Charging Indicators
With PowerBlock Wireless Charging Pad, you’ll always know when your phone is successfully charging. Vibrant LED lights let you know when you have a good charging connection and your phone is receiving the strong charge it needs.
Compatible with Any Qi-Enabled Device
PowerBlock Wireless Charging Pad features the universal Qi wireless charging standard. This means your pad will successfully charge any of the 62 Qi-enabled devices on the market.
- Qi Certified wireless output up to 15 watts
- Supports Samsung fast wireless charging
- Subtle LED underglow activates when phone is charging wirelessly
- Soft material grips and protects device while charging
- Charges through most cases (=3mm)
- Works with Qi-compatible devices
- Power cable with US/EU/UK/AUS adapters provided *Non-slip feet
Rapid charging power
Think wireless charging has to be slow? Think again. The PowerBlock wireless charging base safely and easily charges your Qi-enabled devices faster than standard wireless chargers. -
Effortless charging, every time
To charge your Qi-enabled device with the PowerBlock wireless charging pad, all you have to do is sit your phone on the no-scratch, felted platform. That's it. No cords, no plugs, no fuss. -
LED charging indicators
With PowerBlock wireless charging pad, you'll always know when your phone is successfully charging. Vibrant LED lights let you know when you have a good charging connection and your phone is receiving the strong charge it needs. -
PowerBlock wireless charging pad features the universal Qi wireless charging standard. This means your pad will successfully charge any of the Qi-enabled devices on the market.
- Griffin PowerBlock wireless charging mat - + AC power adapter - 15 Watt
- Product Type
- Wireless charging mat + AC power adapter
- Black
- Voltage Required
- AC 100-240 V
- Wireless Charging
- Wireless Charging Standards
- Qi
- Power Provided
- 15 Watt
- Limited lifetime warranty
- Product Type
- Designed For
- Phone
- Enclosure Colour
- Black
- Voltage Required
- AC 100-240 V
- Power Provided
- 15 Watt
- Wireless Charging
- Qi
- AC Power Adapter Included
- LED indicator
- Material
- Polycarbonate, synthetic wool felt, thermoplastic polyurethane (TPU)
- Limited warranty - lifetime
