Whether you're charging a few iPads or a whole office full of iOS and Android devices, MultiDock provides charging, storage and security where you need it, when you need it.
MultiDock uses Griffin's exclusive ChargeSensor technology to optimize charging. ChargeSensor automatically detects the charging characteristics of each connected device and supplies the charging rate each device needs for fastest, most complete charging. MultiDock works with any combination of iOS and Android devices; charge tablets and smartphones simultaneously.
Compact footprint
Takes up about the same space as an open laptop, yet accommodates up to 10 full-size tablets, e-readers, smartphones or any combination. -
Charge fast and smart
MultiDock uses Griffin's exclusive ChargeSensor technology to optimize charging. ChargeSensor automatically detects the charging characteristics of each connected device and supplies the charging rate each device needs for fastest, most complete charging. MultiDock works with any combination of iOS and Android devices; charge tablets and smartphones simultaneously. -
Charge at the speed of lightning
Connecting an iPad 4, iPad mini or other device that uses Apple's lightning charge/sync connector automatically activates MultiDock's quick charge mode. MultiDock charges these newer devices at the fastest possible rate, even while syncing, thus ensuring that your devices will be fully charged and ready when you need them. -
Built-in flexibility
What starts as an iPad pilot project quickly grows into a system-wide deployment. MultiDock's modular design allows you to stack and secure up to three units with the included hardware.
- Griffin MultiDock 2 - iPad docking station for tablet
- Product Type
- Packaged Quantity
- 3 (specifications are for single item)
- Intended For
- Tablet
- Product Material
- Aluminium, steel, acrylic
- 38.3 cm x 32 cm x 32.3 cm
- 8.44 kg
- Packaged Quantity
- Product Type
- Intended For
- Tablet
- Product Material
- 38.3 cm
- 32 cm
- 32.3 cm
- 8.44 kg
- Connections
- 10 x USB - 4 PIN USB Type A
- Synchronization function, connection via USB, lock, LED indicator, charge up to 10 devices
